Re: cummins engine tech
[Re: Quicktree]
#1705061
12/01/14 12:54 PM
12/01/14 12:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
also i didn't see the fuel shut off move in the on posistion, only when trying to start
Make sure that shut off arm goes all the way open Tony... then if it is start moving backwards to see where the loss of fuel is.. dirty filter or what.. drain the filter also... diesels are pretty easy to figure out ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Dabee]
#1705064
12/01/14 03:43 PM
12/01/14 03:43 PM
Quicktree
You still stranded? I'm 30 min from Gatlinburg. I sent you a message with my phone number, if your still stranded call me in the morning.
Russ what a pleasure meeting and talking with you for a little while. Thanks for coming and hopefully we will get out of here very shortly. anything I can ever do for you just let me know. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Quicktree]
#1705065
12/01/14 07:33 PM
12/01/14 07:33 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
So your Fixed??
[Re: Quicktree]
#1705068
12/02/14 11:25 AM
12/02/14 11:25 AM
MR_P_BODY
thanks for the help everyone. yea we got it going. it was a bad lift pump. we just rolled in 10 hours straight through
My diesel didnt have a in tank lift pump(just the primer pump) with the P pump but I installed a currant in tank lift pump about 5 years ago to up the supply pressure.. now I run 24#-30# supply pressure... you could have strapped on any small low pressure pump in line and got you home.. I have a pump in my truck just in case... good to hear your all set and back home ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1705069
12/02/14 02:17 PM
12/02/14 02:17 PM
Quicktree
yea this one is on the side of the motor just like my 97 dually. how did you guys run the fuel lines with an electric pump?
[Re: Quicktree]
#1705070
12/02/14 02:43 PM
12/02/14 02:43 PM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
You may want to put a fuel pressure gauge on it.
We have a 93 that quit on us. Had it towed home
Same thing found out , bad lift pump
We then put a pyro, boost and fuel pres. on to monitor the engine.
Was told, when we bought it should put gauges on it.
May have saved me a tow bill. would had known what direction to look for the problem
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
[Re: Quicktree]
#1705071
12/02/14 02:46 PM
12/02/14 02:46 PM
MR_P_BODY
I changed over all my fuel lines at the time so I cut the line so I could add in a pump IF NEEDED... but at that time I installed a in tank lift pump.. so if the in tank pump dies I can add in the in line pump to the fuel line.. I even have 12 volts wired to that in line pump location(thats a just in case set up) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: pittsburghracer]
#1705073
12/02/14 04:38 PM
12/02/14 04:38 PM
MR_P_BODY
Just a small heads-up that my Son Matt taught me that he was taught at the truck garage where he does mechanical work. The mechanics there always add 4 ounces of 2 cycle engine oil to the tank of their personal vehicles because of issues caused by today's low sulfur diesel fuel. They still use the fuel conditioner too.
So far I havent used any oil BUT I do use conditioner.. I only drive my rig in the summer months ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Dabee]
#1705074
12/06/14 11:56 AM
12/06/14 11:56 AM
Quicktree
hey Russ do you have any pics of your truck? I am sure the guys would love to see it.
[Re: Quicktree]
#1705077
12/06/14 05:04 PM
12/06/14 05:04 PM
MR_P_BODY
awesome I am sure the guys would love to see that hemi setting in there. hey I knew it was the lift pump
I have cheated on company road trips to get us back home or to a shop... I ran a hose down the filler tube and taped a pump on the 1/4 panel with a couple of wires on it.. then the outlet hose to the pump or engine (depending if its a gas or diesel) but it works to get you home.... of course I had the stuff to do this in the cars we were running(road testing for the company).. thats why I hooked up my new fuel lines like I did with a pump prevision location ![](/ubbthreads/images/graemlins/wave.gif)
