Re: cummins engine tech
[Re: Quicktree]
#1705040
11/30/14 04:22 PM
11/30/14 04:22 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
we are standed up in the mountains in gatlinburg tennessee. not getting fuel i am guessing or hoping it's a lift pump or pre filter. anyone from here? know a good diesel shop? or any ideas?
Pull the line and if it's not getting any fuel get a good electric pump and bypass the stock pump.Get fuel to the injector pump and get on the road.We and others have had similar issues and in a pinch pulled our electric pumps of our race car and got back on the road.
[Re: LaRoy Engines]
#1705043
11/30/14 04:32 PM
11/30/14 04:32 PM
Quicktree
Sometimes the wire to the fuel shutoff comes loose.
where is that at
[Re: Quicktree]
#1705045
11/30/14 07:03 PM
11/30/14 07:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Can be the relay on the fuel shut off valve or the fuse going to the relay... see if the shut off is opening up when you turn the ignition on... if not a tie rap around the shut off arm will work
[Re: MR_P_BODY]
#1705046
11/30/14 09:54 PM
11/30/14 09:54 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
What he said. A 97 8.3 would most likely be a p pump engine. They have a fuel solenoid with two windings. One winding is a high amperage "pull" winding. The other is a low amperage "hold" winding. When you engage the starter, the pull winding is energized, moving the lever on the pump. When you let off of the starter the hold winding takes over. The "pull" side of the solenoid melts every once in a while. Just zip tie the lever and you should be fine. A lot of times you can just hold the lever open by hand while starting, and the hold winding will do it's job. No tools needed. The solenoid and lever are all external.
[Re: Dabee]
#1705049
12/01/14 02:03 AM
12/01/14 02:03 AM
Quicktree
You still stranded? I'm 30 min from Gatlinburg. I sent you a message with my phone number, if your still stranded call me in the morning.
yea we are still here, i sent you a pm.
[Re: TRENDZ]
#1705050
12/01/14 02:07 AM
12/01/14 02:07 AM
Quicktree
is this located on the injector pump?
[Re: Quicktree]
#1705052
12/01/14 02:12 AM
12/01/14 02:12 AM
MR_P_BODY
Yes... you will see a arm with a linkage to a solenoid that pulls it open.. should be on the rear of the pump area
[Re: MR_P_BODY]
#1705053
12/01/14 02:13 AM
12/01/14 02:13 AM
Quicktree
What have you found out so far
not a dam thing, other than the guy that came out last night din't have a clue. he messed with a filter for 2 hours and never checked any of the things you guys mentioned. it looks like a low pressure issue just from what you guys are saying but i really know very little about these things other than changing a lift pump on my dually once. it's also very heard to get under this thing. i'l open up the enging compartment in the morning and look better.
[Re: mopar65]
#1705055
12/01/14 02:55 AM
12/01/14 02:55 AM
Quicktree
here you go quicktree see if this will help you.
http://www.beamalarm.com/Documents/fuel_shut_off_solenoid_replacement.html
yes that was very helpful, thanks. i'll take a look in the morning
