Page 2 of 3 1 2 3
Re: cummins engine tech [Re: Jerry Kathe] #1705058
12/01/14 09:12 AM
12/01/14 09:12 AM
Jerry Kathe Offline
Jerry Kathe  Offline
Should of asked this also.....any white smoke out of the exhaust while cranking. .....even trace amounts?
Re: cummins engine tech [Re: Jerry Kathe] #1705059
12/01/14 12:45 PM
12/01/14 12:45 PM
Q
Quicktree Offline OP
Q
yes there seems to be white smoke when trying to start, what is that from?
Re: cummins engine tech [Re: Quicktree] #1705060
12/01/14 12:46 PM
12/01/14 12:46 PM
Q
Q
also i didn't see the fuel shut off move in the on posistion, only when trying to start
Re: cummins engine tech [Re: Quicktree] #1705061
12/01/14 12:54 PM
12/01/14 12:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Make sure that shut off arm goes all the way open
Tony... then if it is start moving backwards to see
where the loss of fuel is.. dirty filter or what.. drain
the filter also... diesels are pretty easy to figure out
Re: cummins engine tech [Re: Quicktree] #1705062
12/01/14 01:01 PM
12/01/14 01:01 PM
Jerry Kathe Offline
Jerry Kathe  Offline
If you are seeing some white smoke then it is getting "some" fuel. Its possible the grid heater is not working. If you are up there in the hills it was getting pretty cool at night.
If you can positively identify the grid...aka intake....aka preheater in the intake tract, unplug it and wait a few minutes, then hit it with a shot of eather (starting fluid). You may be good to go .....just be conservative with the starting fluid.
Re: cummins engine tech [Re: Jerry Kathe] #1705063
12/01/14 02:04 PM
12/01/14 02:04 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Sounds like your getting some fuel.I would try the simplist check first and see if the pump is getting a good fuel supply.If I'am thinking correctly that pump has a gear drive with a tapered shaft and no keyway.The gear may have slipped on the shaft and has the pump out of time or not spinning it.But first find if your getting fuel to the pump.If it's an electrical problem try using a jumper wire direct from the battery to the fuel shut off and heater.Again if your not getting enough fuel to the injector pump then nothing is going to work.
Re: cummins engine tech [Re: Dabee] #1705064
12/01/14 03:43 PM
12/01/14 03:43 PM
Q
Q
You still stranded? I'm 30 min from Gatlinburg. I sent you a message with my phone number, if your still stranded call me in the morning.
Russ what a pleasure meeting and talking with you for a little while. Thanks for coming and hopefully we will get out of here very shortly. anything I can ever do for you just let me know.
Re: cummins engine tech [Re: Quicktree] #1705065
12/01/14 07:33 PM
12/01/14 07:33 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
So your Fixed??
Re: cummins engine tech [Re: Sport440] #1705066
12/02/14 02:27 AM
12/02/14 02:27 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
So your Fixed??
I spoke to Tony around 3:00 and they where up and running, it was a bad lift pump.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: cummins engine tech [Re: dusturbd340W5] #1705067
12/02/14 04:11 AM
12/02/14 04:11 AM
Q
Q
thanks for the help everyone. yea we got it going. it was a bad lift pump. we just rolled in 10 hours straight through
Re: cummins engine tech [Re: Quicktree] #1705068
12/02/14 11:25 AM
12/02/14 11:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
My diesel didnt have a in tank lift pump(just the
primer pump) with the P pump but I installed a currant
in tank lift pump about 5 years ago to up the supply
pressure.. now I run 24#-30# supply pressure...
you could have strapped on any small low pressure
pump in line and got you home.. I have a pump in
my truck just in case... good to hear your all set
and back home
Re: cummins engine tech [Re: MR_P_BODY] #1705069
12/02/14 02:17 PM
12/02/14 02:17 PM
Q
Q
and back home
yea this one is on the side of the motor just like my 97 dually. how did you guys run the fuel lines with an electric pump?
Re: cummins engine tech [Re: Quicktree] #1705070
12/02/14 02:43 PM
12/02/14 02:43 PM
smyrna,tn
draginmopars Offline
smyrna,tn
You may want to put a fuel pressure gauge on it.
We have a 93 that quit on us.
Had it towed home
Same thing found out , bad lift pump
We then put a pyro, boost and fuel pres. on
to monitor the engine.
Was told, when we bought it
should put gauges on it.
May have saved me a tow bill.
would had known what direction to look for the problem
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: cummins engine tech [Re: Quicktree] #1705071
12/02/14 02:46 PM
12/02/14 02:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
and back home
I changed over all my fuel lines at the time so I
cut the line so I could add in a pump IF NEEDED...
but at that time I installed a in tank lift pump..
so if the in tank pump dies I can add in the in line
pump to the fuel line.. I even have 12 volts wired
to that in line pump location(thats a just in case
set up)
Re: cummins engine tech [Re: MR_P_BODY] #1705072
12/02/14 04:24 PM
12/02/14 04:24 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Just a small heads-up that my Son Matt taught me that he was taught at the truck garage where he does mechanical work. The mechanics there always add 4 ounces of 2 cycle engine oil to the tank of their personal vehicles because of issues caused by today's low sulfur diesel fuel. They still use the fuel conditioner too.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: cummins engine tech [Re: pittsburghracer] #1705073
12/02/14 04:38 PM
12/02/14 04:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
So far I havent used any oil BUT I do use conditioner..
I only drive my rig in the summer months
Re: cummins engine tech [Re: Dabee] #1705074
12/06/14 11:56 AM
12/06/14 11:56 AM
Q
Q
hey Russ do you have any pics of your truck? I am sure the guys would love to see it.
Re: cummins engine tech [Re: Quicktree] #1705075
12/06/14 04:10 PM
12/06/14 04:10 PM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
Tony, here you go. I had a thread on the Street Rod section while I was building it. This picture was taken while I was visiting Dodgem up in Kitchner Ontairio last year.
Re: cummins engine tech [Re: Dabee] #1705076
12/06/14 04:46 PM
12/06/14 04:46 PM
Q
Q
awesome I am sure the guys would love to see that hemi setting in there. hey I knew it was the lift pump
Re: cummins engine tech [Re: Quicktree] #1705077
12/06/14 05:04 PM
12/06/14 05:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have cheated on company road trips to get us back home
or to a shop... I ran a hose down the filler tube and
taped a pump on the 1/4 panel with a couple of wires
on it.. then the outlet hose to the pump or engine
(depending if its a gas or diesel) but it works to
get you home.... of course I had the stuff to do this
in the cars we were running(road testing for the company)..
thats why I hooked up my new fuel lines like I did
with a pump prevision location
Page 2 of 3 1 2 3
