Page 1 of 3 1 2 3
cummins engine tech #1705038
11/30/14 04:14 PM
11/30/14 04:14 PM
Q
Quicktree Offline OP
Q
we are standed up in the mountains in gatlinburg tennessee. not getting fuel i am guessing or hoping it's a lift pump or pre filter. anyone from here? know a good diesel shop? or any ideas?
Re: cummins engine tech [Re: Quicktree] #1705039
11/30/14 04:21 PM
11/30/14 04:21 PM
Idaho
LaRoy Engines Offline
Idaho
Sometimes the wire to the fuel shutoff comes loose.
Re: cummins engine tech [Re: Quicktree] #1705040
11/30/14 04:22 PM
11/30/14 04:22 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Pull the line and if it's not getting any fuel get a good electric pump and bypass the stock pump.Get fuel to the injector pump and get on the road.We and others have had similar issues and in a pinch pulled our electric pumps of our race car and got back on the road.
Re: cummins engine tech [Re: B G Racing] #1705041
11/30/14 04:25 PM
11/30/14 04:25 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
What year truck?
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: cummins engine tech [Re: DragDart360] #1705042
11/30/14 04:31 PM
11/30/14 04:31 PM
Q
Q
it's 97 monaco motor home with a cummins 8.3. i don't have enough tools to do anything
Re: cummins engine tech [Re: LaRoy Engines] #1705043
11/30/14 04:32 PM
11/30/14 04:32 PM
Q
Q
where is that at
Re: cummins engine tech [Re: Quicktree] #1705044
11/30/14 05:32 PM
11/30/14 05:32 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: cummins engine tech [Re: Quicktree] #1705045
11/30/14 07:03 PM
11/30/14 07:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Can be the relay on the fuel shut off valve or the
fuse going to the relay... see if the shut off is
opening up when you turn the ignition on... if not
a tie rap around the shut off arm will work
Re: cummins engine tech [Re: MR_P_BODY] #1705046
11/30/14 09:54 PM
11/30/14 09:54 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
What he said. A 97 8.3 would most likely be a p pump engine. They have a fuel solenoid with two windings. One winding is a high amperage "pull" winding. The other is a low amperage "hold" winding. When you engage the starter, the pull winding is energized, moving the lever on the pump. When you let off of the starter the hold winding takes over. The "pull" side of the solenoid melts every once in a while. Just zip tie the lever and you should be fine. A lot of times you can just hold the lever open by hand while starting, and the hold winding will do it's job. No tools needed. The solenoid and lever are all external.
Re: cummins engine tech [Re: Quicktree] #1705047
11/30/14 10:08 PM
11/30/14 10:08 PM
Jerry Kathe Offline
Jerry Kathe  Offline
That sucks, I just left there yesterday afternoon. Look at what TRENZ said, that would be my suspicion also. I have also seen relays and the fusible links fail in those systems.
Re: cummins engine tech [Re: Quicktree] #1705048
12/01/14 01:04 AM
12/01/14 01:04 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
You still stranded? I'm 30 min from Gatlinburg. I sent you a message with my phone number, if your still stranded call me in the morning.
Re: cummins engine tech [Re: Dabee] #1705049
12/01/14 02:03 AM
12/01/14 02:03 AM
Q
Q
yea we are still here, i sent you a pm.
Re: cummins engine tech [Re: TRENDZ] #1705050
12/01/14 02:07 AM
12/01/14 02:07 AM
Q
Q
is this located on the injector pump?
Re: cummins engine tech [Re: Quicktree] #1705051
12/01/14 02:09 AM
12/01/14 02:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What have you found out so far
Re: cummins engine tech [Re: Quicktree] #1705052
12/01/14 02:12 AM
12/01/14 02:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes... you will see a arm with a linkage to a solenoid
that pulls it open.. should be on the rear of the
pump area
Re: cummins engine tech [Re: MR_P_BODY] #1705053
12/01/14 02:13 AM
12/01/14 02:13 AM
Q
Q
not a dam thing, other than the guy that came out last night din't have a clue. he messed with a filter for 2 hours and never checked any of the things you guys mentioned. it looks like a low pressure issue just from what you guys are saying but i really know very little about these things other than changing a lift pump on my dually once. it's also very heard to get under this thing. i'l open up the enging compartment in the morning and look better.
Re: cummins engine tech [Re: Quicktree] #1705054
12/01/14 02:49 AM
12/01/14 02:49 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
here you go quicktree see if this will help you.
http://www.beamalarm.com/Documents/fuel_shut_off_solenoid_replacement.html
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: cummins engine tech [Re: mopar65] #1705055
12/01/14 02:55 AM
12/01/14 02:55 AM
Q
Q
yes that was very helpful, thanks. i'll take a look in the morning
Re: cummins engine tech [Re: Quicktree] #1705056
12/01/14 08:37 AM
12/01/14 08:37 AM
Q
Q
well i got up this morning and the fuel shut off looks like it's working. was hoping for quick fix
Re: cummins engine tech [Re: Quicktree] #1705057
12/01/14 09:07 AM
12/01/14 09:07 AM
Jerry Kathe Offline
Jerry Kathe  Offline
So it is retracted in both the crank and run positions? Be sure of that, as mentioned, they fail in the crank position most often.
If you are beyond that, have someone crank it over while you crack the lines loose at the injectors, should see fuel get pushed out. If there is bubble's then it lost its prime for some reason.....no fuel...then keep going backwards in the system.
Try to prime the system using the manual plunger at the mechanical lift pump. See if it pushes fuel at the canister filter using the plunger.
Page 1 of 3 1 2 3
