1970 A833 4 speed clutch adjustment #1704907
11/30/14 02:20 PM
11/30/14 02:20 PM
midwest - USA
69/70 Plymies Offline OP
midwest - USA
If I recall correctly, the adjustment for this clutch is .040" between the clutch plate and the flywheel. My question is whether this is a minimum and more is ok or is this where it should be(no more or less)? Presently, I have 1" free travel at the pedal, but the clutch clearance is more than .040", probably around .060-.070". Brand new McLeod clutch and don't want to mess it up!
Re: 1970 A833 4 speed clutch adjustment [Re: 69/70 Plymies] #1704908
11/30/14 02:26 PM
11/30/14 02:26 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I prefer .060 myself for nice clean powershifts and as long as you have good free-play you should be good. I like a good positive stop on the floor so you don't push it too far
Gus
64 Plymouth Savoy
Dana 60
Re: 1970 A833 4 speed clutch adjustment [Re: fourgearsavoy] #1704909
11/30/14 04:32 PM
11/30/14 04:32 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 1970 A833 4 speed clutch adjustment [Re: 68LAR] #1704910
12/01/14 11:00 PM
12/01/14 11:00 PM
midwest - USA
midwest - USA
So,is 1" pedal free-play where I want to be?
Re: 1970 A833 4 speed clutch adjustment [Re: 69/70 Plymies] #1704911
12/01/14 11:16 PM
12/01/14 11:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
No, .060" plate departure is where you want to be, pedal free play will be whatever it is. That's the least important issue. As long as there is any free play you are ok.
Don't be the exception.
Re: 1970 A833 4 speed clutch adjustment [Re: Supercuda] #1704912
12/02/14 02:25 AM
12/02/14 02:25 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
EXACTLY
