Re: Another Gen-III Hemi E-body swap
[Re: ntstlgl1970]
#1704770
01/21/15 06:07 PM
01/21/15 06:07 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
It only took them them 3 weeks to get mine made, I guess im lucky.
Mopar to the bone!!!
[Re: Chally426]
#1704775
01/22/15 11:36 PM
01/22/15 11:36 PM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
I got a pan, pick up, dipstick tube and new indicator from modern muscle, said they had them on the shelf as a kit
Sure...NOW you tell us!
2 Demons...no, not my kids!
[Re: ntstlgl1970]
#1704778
01/24/15 01:41 PM
01/24/15 01:41 PM
72Swinger
Nebraska
I think the screen end of the factory pickup is to big to allow the doors to open in the RR pan.
[Re: RylisPro]
#1704781
02/04/15 03:24 AM
02/04/15 03:24 AM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
I'd like to use a superdamper, but that is something that can be swapped out in the car. So I'll do that later.
Meanwhile, I worked on the motor mount brackets. With other posts I have read regarding mounts, headers and other parts not fitting correctly, I wanted to spend the time to make sure things go together smoothly prior to dropping the motor in the car. Of course there was much grinding to be done, the passenger side bracket hit part of the block casting, so I had to grind that corner of the bracket so that the bracket could be bolted to the block (it would not line up without this clearancing). In addition, the holes for the mount stud are little too small, so I had to drill those oversize. I also had to grind the stud shorter so it would not bottom out in the bracket, clean up the mounting surfaces on the mounts so they would sit flat against the bracket and also on the K-member. And lastly, I had to grind the pad of the motor mount where it was contacting the header tube on #1 cylinder.
[Re: ntstlgl1970]
#1704786
02/04/15 04:16 AM
02/04/15 04:16 AM
ntstlgl1970
Sac, CA, USA
To offset the good progress made was all the bad stuff I found when swapping parts for the transmission. going from the big block to the hemi meant I have to swap trans cases. Since I rebuilt the trans prior to putting it behind the big block, I need to swap all the parts out of the case into a small block case. When I got the trans out of the car and tore into it, there was some bad news. 1 - the converter either ballooned or there was not enough clearance when the parts were bolted together. The converter was hitting the front pump seal, which wore a groove into the base of the converter drive hub. I will end up having to send the converter back to get checked out and see if they can set it up with a shorter assembled height if it was not ballooned. 2 - the TCS direct drum in the trans has a bronze bushing insert in the aluminum. The stator support seals wore pretty serious grooves into the bushing so I'll have to replace that prior to putting the trans back together. I was surprised at the amount of wear considering the low miles on the trans. From what I understand from another post on here, the seals provided with the drum are pretty aggressive. I need to talk to TCS and see if there are any options on using a different seal. I was starting to have issues with clutch chatter in reverse and I guess this was the source. I guess I just expect too much from these parts. It's pretty aggravating.
