Re: Another Gen-III Hemi E-body swap
[Re: ntstlgl1970]
#1704749
12/10/14 05:55 PM
12/10/14 05:55 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Up late again, Eric?
Greg- you should come by and check this thing out, it's pretty cool
You should have called. I have a truck and a "knock down" cherry picker. NO need to resort to the Tom Foolery of jackstands and tire removal to load or unload an engine.
[Re: haddixj]
#1704752
12/12/14 11:59 PM
12/12/14 11:59 PM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
Probably going to run an LS type 90mm with a adapter.
Bad news is that the pistons have some scuffing damage - like I said, I didnt know the history on this engine - so i'll have to have the block honed, I hope it will clean up with just a .005" overbore. Talked to Arrow today, turns out it is a 426 crate motor.
[Re: ntstlgl1970]
#1704753
12/13/14 11:05 PM
12/13/14 11:05 PM
ntstlgl1970
Sac, CA, USA
finally finished tear down - source of the issue(s) is #4 main bearing spun. Oil Passages are clear so either it got run out of oil or clearance was too tight on the mains. main spun, material sent to #6 and 7 rods, crap in those rod bearings, sent into bore, picked up by rear 4 pistons and dragged around. all other journals look ok. Will have to have crank ground on main journals, polish on rod journals, block checked and line bored as needed and 8 new pistons. might also need one intake valve along with corresponding rocker that looks like it mushroomed the valve tip a little or might clean up on the grinder.
[Re: ntstlgl1970]
#1704756
12/14/14 12:51 AM
12/14/14 12:51 AM
Posts: 2,432 NorCal
RylisPro
NorCal
Wow hopefully you got a good deal on that engine! I'm pretty sure that has Callies Compstar rods. Nothing wrong with them, but I wanted US made rods instead. Todd at Arrow was able to get me a set of Dryer I-beam rods that has the necessary offset.
[Re: RylisPro]
#1704757
12/14/14 12:58 AM
12/14/14 12:58 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Probably not necessary, but one advantage to the aluminum blocks is sleeves are cheap and replaceable. Those look like Mahle pistons. Get well informed on proper head sealing technique. What bore is it? 4.125?
Mopar to the bone!!!
[Re: Kern Dog]
#1704764
01/05/15 11:56 PM
01/05/15 11:56 PM
ntstlgl1970
Sac, CA, USA
Are those rods easy to resize? I've always played it safe with rebuild of engines with spun bearings, opting to have the rods resized. If it was only a main bearing that spun, it still may be wise to "mike" the big ends of the rods to ensure their size.
I'm going to go through everything and see where they setup the bearing clearances. Though I found the symptoms of the problem, I'm not confident I found the source yet. When I talked to Arrow, there were no special machining operations for the aluminum block that differed from other engines, I was happy to hear that. I wish I still had access to machine shop equipment like I did in San Jose. I had to buy a dial bore gauge so I can check the rods, mains etc. But I don't mind buying tools....
[Re: RylisPro]
#1704765
01/21/15 12:19 AM
01/21/15 12:19 AM
ntstlgl1970
Sac, CA, USA
Hey just a heads up on the Milodon 18336 pickup. Apparently they don't have enough materials for the tubes so they are on back order for at least 3 weeks. When I called yesterday the guy said he had three 31003 oil pans just sitting there waiting on a pickup
I know you were looking for one as well
Just got an email from summit, that the pickup will be ANOTHER 4 weeks! great, the pickup will be the one thing keeping me from getting this running....
[Re: RylisPro]
#1704767
01/21/15 02:10 AM
01/21/15 02:10 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
Frustrating, to say the least. I'm waiting for one too! The part I don't get, is why does this not come as a package? The pan requires that pickup, so why do they not come together?
2 Demons...no, not my kids!
[Re: 4speeds4me]
#1704768
01/21/15 02:25 AM
01/21/15 02:25 AM
Posts: 2,432 NorCal
RylisPro
NorCal
Supply and demand. Milodon is too busy making money off of Chevy and Ford products to even notice us Mopar fans. We are lucky enough to know that they even exist and have the part numbers. Not very many people out there with late model hemi swaps and even less that actually road race them.
