Re: Another Gen-III Hemi E-body swap
[Re: ntstlgl1970]
#1704730
11/30/14 02:47 AM
11/30/14 02:47 AM
Posts: 2,432 NorCal
RylisPro
NorCal
That's awesome! Planning to go Gen3 next year also. Will be interested in your install. I read somewhere that when you bolt the bellhousing to the block there is a misalignment from the trans to the flywheel? Maybe the Gen3 experts can chime in! ![](http://i101.photobucket.com/albums/m69/arielrylis/bluethumb.gif)
[Re: RylisPro]
#1704731
11/30/14 03:02 AM
11/30/14 03:02 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Usually need the Mopar Peformance conversion flexplate.
Mopar to the bone!!!
[Re: ntstlgl1970]
#1704734
11/30/14 10:52 AM
11/30/14 10:52 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Awesome! Looking forward to watching your build. For wiring and setting up your megasquirt, go to my DIY how to thread here: http://www.forabodiesonly.com/mopar/showthread.php?t=226125Covers wiring, tuner studio set-up for the Hemi, etc. It will get you running. Everything should line up fine with the swap flexplate. I believe the bushing in the crank stays??? Someone else can chime in on this hopefully. ![](/ubbthreads/images/graemlins/thumbs.gif)
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: ntstlgl1970]
#1704737
12/10/14 02:42 AM
12/10/14 02:42 AM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
got a surprise - engine showed up a day early.
Also- the shipping weight was 500 lbs. 80 lbs of that was the pallet and the cardboard packing (yeah, I weighed it), so this engine weighs in around 420 lbs.
This is a long block, with intake, throttle body, exhaust, LC/LX cast aluminum oil pan and coil packs. No fluids.
[Re: Kern Dog]
#1704742
12/10/14 12:53 PM
12/10/14 12:53 PM
ntstlgl1970
Sac, CA, USA
Yesterday was a very long day... I had planned everything out for today so there was some serious backyard engineering we had to do. Since the engine came in a day early, had to take off from work unscheduled, my buddy with the truck had to take off from work unscheduled also, go pickup the engine at my wife's workplace before it got buried in the warehouse, then get it into the garage without the benefit of a cherry picker. Ever try to get an engine on a pallet out of the back of a truck without a cherry picker? This was a little scary ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: Kern Dog]
#1704744
12/10/14 01:03 PM
12/10/14 01:03 PM
ntstlgl1970
Sac, CA, USA
Up late again, Eric?
Greg- you should come by and check this thing out, it's pretty cool ![](/ubbthreads/images/graemlins/bow.gif)
[Re: RylisPro]
#1704746
12/10/14 02:14 PM
12/10/14 02:14 PM
ntstlgl1970
Sac, CA, USA
I went and checked the bill of lading and it says ship weight of 500 lbs (it seems odd to be it is exactly 500 lbs but ok!). I've edited my initial post....
[Re: ntstlgl1970]
#1704748
12/10/14 03:32 PM
12/10/14 03:32 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Hey just a heads up on the Milodon 18336 pickup. Apparently they don't have enough materials for the tubes so they are on back order for at least 3 weeks. When I called yesterday the guy said he had three 31003 oil pans just sitting there waiting on a pickup I know you were looking for one as well ![](http://i101.photobucket.com/albums/m69/arielrylis/bluethumb.gif)
