68 Charger green/white A pillar question. WHICH COLOR? #1704566
11/29/14 04:48 PM
11/29/14 04:48 PM
Elk Grove, CA
challngr08 Offline OP
Elk Grove, CA
I have a 68 charger Im restoring and it is coded on the tag for green/white interior. Since the car is in original state I know that the carpet is dark green along with dash, seats/door panels/upper panels are white. However the A pillar interior moldings are missing. Would these also be dark green? Im leaning that way, but I wanted to check and make sure they werent white. I dont know if Ive seen any white A pillar moldings though. Somebody out there know? Thanks!!
Re: 68 Charger green/white A pillar question. WHICH COLOR? [Re: challngr08] #1704567
11/29/14 05:15 PM
11/29/14 05:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
green, no white
Re: 68 Charger green/white A pillar question. WHICH COLOR? [Re: challngr08] #1704568
11/29/14 07:57 PM
11/29/14 07:57 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
A pillars are always the same color as the dash , same for the moulding across the top header above the mirror
Re: 68 Charger green/white A pillar question. WHICH COLOR? [Re: gtx6970] #1704569
11/30/14 11:13 AM
11/30/14 11:13 AM
Northern BC
Canucklehead Offline
Northern BC
Not true, my 69 Dart convertible has a blue/white interior, dash is blue, pillars and doors are white. A-body may be different, I guess. Dash, column, carpet and seat belts are blue, seats, door panels, upper door frames, a-pillars and header are white.
Re: 68 Charger green/white A pillar question. WHICH COLOR? [Re: Canucklehead] #1704570
11/30/14 01:45 PM
11/30/14 01:45 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
E bodies are another "story" as well, but the OP was questioning 2nd gen Chargers, no white A pillars on 2nd gens, even in an all white interior
