Now show low mount alt and vacuum pumps. #170358
12/18/08 09:57 PM
12/18/08 09:57 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
How about low mount alternators and vacuum pumps. And why the pump you have works best. This will be a 540ci nitrous motor(probably a 350 shot).
Re: Now show low mount alt and vacuum pumps. [Re: 4404dart] #170359
12/18/08 10:54 PM
12/18/08 10:54 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
heres my setup
1.39 9.85 - 137 mph
Re: Now show low mount alt and vacuum pumps. [Re: Ari440] #170360
12/18/08 10:57 PM
12/18/08 10:57 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
Wow, thanks for the pics. I see alot of Moroso stuff, does that include the drive mandrel?
Re: Now show low mount alt and vacuum pumps. [Re: Ari440] #170361
12/18/08 10:59 PM
12/18/08 10:59 PM
Delmont, Pa.
SRT8Challenger Offline
Delmont, Pa.
Ari440, that is one cool set up.
Mean and clean! Looks fast just sitting there!
Ed
Re: Now show low mount alt and vacuum pumps. [Re: 4404dart] #170362
12/18/08 11:02 PM
12/18/08 11:02 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
$850 for the moroso 3 vane kit
mendrel drive was part of it too
got some fittings relief valve a vacume gauge and #4 line for it
almost $1000 all together
1.39 9.85 - 137 mph
Re: Now show low mount alt and vacuum pumps. [Re: SRT8Challenger] #170363
12/18/08 11:06 PM
12/18/08 11:06 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Ed
thank you ED
ANDYF,s
moterplate and low mount altenater , mazeire water pump (35 gpm )and the moroso kit
1.39 9.85 - 137 mph
Re: Now show low mount alt and vacuum pumps. [Re: Ari440] #170364
12/19/08 01:55 AM
12/19/08 01:55 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well here is one that is not easy to see but you get the idea..
Re: Now show low mount alt and vacuum pumps. [Re: Al_Alguire] #170365
12/19/08 02:42 AM
12/19/08 02:42 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Now show low mount alt and vacuum pumps. [Re: Al_Alguire] #170366
12/19/08 10:41 AM
12/19/08 10:41 AM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
What a class engine, and car!
Re: Now show low mount alt and vacuum pumps. [Re: bigtimeauto] #170367
12/19/08 10:42 AM
12/19/08 10:42 AM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
Very nice. What kind of water pump is that?
Re: Now show low mount alt and vacuum pumps. [Re: 4404dart] #170368
12/19/08 10:58 AM
12/19/08 10:58 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Thank you, The pump is a CSR reverse flow pump.
Re: Now show low mount alt and vacuum pumps. [Re: 4404dart] #170369
12/19/08 11:10 AM
12/19/08 11:10 AM
Only real shot of the v-pump on the Aspen....
motor before dyno[silver car].........[better pic]
Re: Now show low mount alt and vacuum pumps. [Re: bigtimeauto] #170370
12/19/08 11:10 AM
12/19/08 11:10 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Here is another picture before the new water pump and a few other trinkets.
Re: Now show low mount alt and vacuum pumps. #170371
12/19/08 12:32 PM
12/19/08 12:32 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
Thanks. I see a couple of trick parts on that car, very cool!
Re: Now show low mount alt and vacuum pumps. [Re: Al_Alguire] #170372
12/19/08 12:34 PM
12/19/08 12:34 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
Thanks. Where is everyone hooking up the vacuum gauge to? Intake manifold?
Re: Now show low mount alt and vacuum pumps. [Re: 4404dart] #170373
12/19/08 12:38 PM
12/19/08 12:38 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
NO you need to take a crankcase vacuum reading. So mine is plumed to read vac at the back of the drivers side valve cover. If you take the reading in the intake you are reading engine vacuum, which has nothing to do with a vacuum pump. You need to measure crankcase vacuum.
Re: Now show low mount alt and vacuum pumps. [Re: Al_Alguire] #170374
12/19/08 01:21 PM
12/19/08 01:21 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
I knew that? Thanks.
Re: Now show low mount alt and vacuum pumps. [Re: 4404dart] #170375
12/19/08 06:20 PM
12/19/08 06:20 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
back of the right side valve cover
1.39 9.85 - 137 mph
Re: Now show low mount alt and vacuum pumps. [Re: Ari440] #170376
12/19/08 06:36 PM
12/19/08 06:36 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I hook the vac gauge to the valley pan. The relief is built into the pump. Not sure how much truth there is to this but they claim with the relief in a valve cover it could draw dirt into the motor. It can also cause a draft and pull more oil. With the relief built in the pump the motor only see's what it needs to achieve the vac you want to pull. With the relief in the VC, the motor sees all the vac the pump can pull with a cool draft blowing thruogh the motor.
Re: Now show low mount alt and vacuum pumps. [Re: Bigcube] #170377
12/19/08 07:59 PM
12/19/08 07:59 PM
Chicagoland
chargerron69 Offline
Chicagoland
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
