Holes in the bottom of 67 Belvedere core support? #1703239
11/25/14 08:04 PM
11/25/14 08:04 PM
Minnesota
DLewis Offline OP
DLewis  Offline OP
Minnesota
Installing a stiffeners kit and curious if I'll want any of these 3 holes in the bottom of the core support before I weld them up.
Re: Holes in the bottom of 67 Belvedere core support? [Re: DLewis] #1703240
11/25/14 09:00 PM
11/25/14 09:00 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the small hole on the left should have a blind nut like you have on the right---i bet a panel bolts in there----the other holes look factory and i bet they let water and other debris fall out of the radiator support area....
Re: Holes in the bottom of 67 Belvedere core support? [Re: savoy64] #1703241
11/25/14 09:11 PM
11/25/14 09:11 PM
Minnesota
DLewis Offline OP
DLewis  Offline OP
Minnesota
Thanks! Yeah, I wasn't going to touch the smaller ones, just the holes in the very bottom that were covered by the stiffener.
