.528 cam suggestion #1703156
11/25/14 02:54 AM
11/25/14 02:54 AM
NY VA USA
GTXbound Offline OP
GTXbound  Offline OP
NY VA USA
Hey Guys
I have a 68 GTX 4 speed dana with 4:10's
Just finishing the motor up.
hoping it we live on 93 pump gas
specs
440 .030 over
TRW 2355 10.38 comp DCR (7.96:1)
piston .020 in the hole
915 heads 81cc 2.14 int 1.74 ex
steel shim MR gaskets .018
.038 piston to head good quench motor
I have a MP .528 cam on the shelf since 1992
so i decided to use it.
just wanted some advice on where i should install
the cam.
Rite now straight up dot to dot the cam is 106 ICL
Thanks guys
Re: .528 cam suggestion [Re: GTXbound] #1703157
11/25/14 08:35 AM
11/25/14 08:35 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I think it is ground on a 112° LSA, correct?
If it is, I would put it in at 112° or 114°.
Let us know how it works out on pump gas.
Re: .528 cam suggestion [Re: BSB67] #1703158
11/25/14 10:23 AM
11/25/14 10:23 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Should run good. I had almost the same motor topped w/ a six pack. Pulled hard. I did go a little tighter on the lash than what was on the cam card.
Re: .528 cam suggestion [Re: Mr.Yuck] #1703159
11/25/14 11:01 AM
11/25/14 11:01 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I had a combo like that. It ran great! I used to hose it down a little bit. I never put a time on it that way but there were nights on 11th street nobody would bite.
That was so long ago I dont remember where I put the cam. Probably straight up
Re: .528 cam suggestion [Re: Mr.Yuck] #1703160
11/25/14 02:20 PM
11/25/14 02:20 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
With iron heads and block I would tighten the cold lash up about .005
Some will disagree but I hate a noisy valvetrain
Gus
64 Plymouth Savoy
Dana 60
Re: .528 cam suggestion [Re: fourgearsavoy] #1703161
11/25/14 02:22 PM
11/25/14 02:22 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Gus
I think the suggested lash is .032/.028 I went .028/.024 I think. That was after setting them per the card. The 6 pack seemed to like that better.
Re: .528 cam suggestion [Re: Mr.Yuck] #1703162
11/25/14 05:43 PM
11/25/14 05:43 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I always put the .528 (112 centers) in a 440 at 108 and a 340/383 at 106 so you're in the ballpark.
WIZE
In Car:
Re: .528 cam suggestion [Re: Streetwize] #1703163
11/25/14 05:50 PM
11/25/14 05:50 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Please degree it in and don't just do "dot to dot".
I installed it straight up in my 440 and tightened up the lash a little. Car ran really well for being a stock motor other thsn headers and this cam.
Re: .528 cam suggestion [Re: GY3] #1703164
11/25/14 06:15 PM
11/25/14 06:15 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I'd run it right where you have it at 106.
Some people don't like the MP cams in general, but, That's one of the best of breed. I really like that camshaft.
I lash at .022-.024
Re: .528 cam suggestion [Re: GTXbound] #1703165
11/25/14 07:04 PM
11/25/14 07:04 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
That is a really good cam.Try it where it sits now.You can always fiddle with it later if you want.
Nautilus Racing-
Re: .528 cam suggestion [Re: Chris2581] #1703166
11/26/14 07:50 PM
11/26/14 07:50 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
....I went 11:20s at 120 in a 3300lbs Duster with that cam. It was a 440, 906 heads, 10.5 TRW piston, M1 single plane intake, very simple engine. It pulled 15in of vacuum at idle and was very streetable.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: .528 cam suggestion [Re: RobX4406] #1703167
11/26/14 10:30 PM
11/26/14 10:30 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I lash at .022-.024
Run it where you have it.
