Re: Adding headrests to bucket seat question
[Re: 440mopar]
#1703071
11/24/14 11:58 PM
11/24/14 11:58 PM
Posts: 7,546 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I thought I read once somewhere that starting in 69 that all the seats were prepped at the factory for headrests for ease of adding them at a later date by the dealer but I don't know if this is true. I haven't taken the upholstery off the seats yet but was just curious if the seats might be headrest ready.
I heard the same and I believe it started even earlier, which was the case on my '67 Satellite when I had it reupholstered - the two holes for a headrest were in the top frame of each front bucket seat.
I'm not sure whether A bodies followed the same spec as B bodies, but by mid-'69 headrests were mandatory.
If you're reupholstering anyway, I'd crack one open and look, so you can go shopping for parts before you send them out for reupholstering.
Best, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: fastmark]
#1703073
11/25/14 01:50 AM
11/25/14 01:50 AM
Posts: 732 USA
440mopar
USA
The provision for installing them is there. In other words the holes are in the seat frames.
What I read about the seats being prepped for headrests indicated that the seats were prepped with the internal parts in place (not just the holes in the frame) so that if headrests were to be installed at a later date the covers wouldn't have to be taken off to do so. Only the holes would need to be cut in the upholstery where the headrest posts go into the seat and then the chrome bezels installed.
