Too much Carb?? #1703046
11/24/14 10:25 PM
11/24/14 10:25 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I have an 800 cfm AVS that I picked up for my Barracuda. I built a 416 stroker for it and here are some of the specs:
416 cid
Edelbrock Performer RPM intake
Comp Cam 292H series .501 lift (I&E) 244 duration (I&E) at .050 106 centerline 110 separation
Dougs Headers w/ 2" primaries and 3" collectors
3" exhaust
4 spd
3.55 gears in rear
Do you think 800 cfm is too much for this setup?
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Too much Carb?? [Re: Erik] #1703047
11/24/14 10:38 PM
11/24/14 10:38 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Nope, but the headers are too big if they are really 2 inch primaries. The cam may be a bit big. Just depends on your personal preference. I'm guessing it may feel a little soft under 3500.
Re: Too much Carb?? [Re: Erik] #1703048
11/24/14 10:47 PM
11/24/14 10:47 PM
You're fine on the carb. If you are up & running I would tune it. If those parts are a wish list as said I would get 1&3/4 pri tubes (maybe 1&7/8-depends). What heads? ported? what is the SCR? Is that measured?
Re: Too much Carb?? [Re: Erik] #1703049
11/24/14 10:47 PM
11/24/14 10:47 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
Carb is ok, header primaries should be more like 1-3/4 and not enough gear for that cam.
Re: Too much Carb?? [Re: Dan Halen] #1703050
11/24/14 10:49 PM
11/24/14 10:49 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I was wrong on the headers - primaries are 1 5/8.
Heads are ported J heads.
SCR?? I don't understand that one.
Re: Too much Carb?? [Re: forphorty] #1703051
11/24/14 10:53 PM
11/24/14 10:53 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Tighten up the secondary air door so there's more resistance to its opening. Most of these I've worked on that door has been set loose so it flops open when the secondary's are opened. That's not the way it works. As the engine needs more air and fuel that secondary air door opens against the air passing over it. Also a good wide AF meter can tell you the AF Ratio to adjust the jets, metering rods, springs, etc. Thats a great carb set up correctly. There's a couple of good books out there on setting it up. Always go for the low hanging fruit before you think about changing things up. You can chase your tail forever doing that.
Re: Too much Carb?? [Re: Erik] #1703052
11/24/14 10:55 PM
11/24/14 10:55 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I think you will be fine with that carburetor and with a 4 speed I think the cam will be just right for a street car.
You didn't mention what you have for cylinder heads
BTW I think you could get more out of that combo with a 557 solid cam if you have the flow for it
Gus
64 Plymouth Savoy
Dana 60
Re: Too much Carb?? [Re: fourgearsavoy] #1703053
11/24/14 10:56 PM
11/24/14 10:56 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Gus
Ported j heads
Re: Too much Carb?? [Re: Erik] #1703054
11/24/14 11:32 PM
11/24/14 11:32 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree that carb is fine for your combo. I also agree with "Cudajon" as the secondary air door adjustment is very important on the AVS. If it opens to soon it may stumble and hesitate. Its important to have the air valve spring tension right so it opens at the right time. Many carbs also use the choke pull-off to slow down the air valve opening so its not to fast and dont bog down. But I dont think the AVS uses the choke pull-off to work with its air valve. Ron
Re: Too much Carb?? [Re: 383man] #1703055
11/25/14 02:58 AM
11/25/14 02:58 AM
Clarified combo list sounds good ex for guys said the cam is too much (I ain't a cam guy). Dial in the carb/dist & let er rip. Get the carb in the ballpark then the dist spot on then final fine tune on the carb. SCR= static compression ratio
Re: Too much Carb?? [Re: RapidRobert] #1703056
11/25/14 09:44 AM
11/25/14 09:44 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Compression ratio! Duh! 10:1
Re: Too much Carb?? [Re: Erik] #1703057
11/25/14 10:20 AM
11/25/14 10:20 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
I think you'll be fine. Remember, they put a 990 cfm setup on a stock 340...or so they said it was lol
Re: Too much Carb?? [Re: terzmo] #1703058
11/25/14 12:44 PM
11/25/14 12:44 PM
Earth
Rob C Offline
Rob C  Offline
Earth
990 CFM? Never ever heard that one.
Stock TQ's are commonly refered to as 800 & 850 CFM units. The 340 had both on top. The largest Carter on top was a 630 AVS.
The 1250 CFM 6 packs in 4bbl. terms was a 780 rating.
Follow the above advice on the secondary air door. Tighten it up.
Re: Too much Carb?? [Re: Rob C] #1703059
11/26/14 09:01 PM
11/26/14 09:01 PM
Chicago suburbs
dartgame Offline
dartgame  Offline
Chicago suburbs
You'll be fine - Im using a 71 440 AVS on my 328 - (318 +060), mild hot rod. Runs the same as the holly street avenger I had on it before, except it does not chew through gas nearly as fast.
Re: Too much Carb?? [Re: Rob C] #1703060
11/26/14 11:31 PM
11/26/14 11:31 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
990cfm was on the 340 6 pak setup
Re: Too much Carb?? [Re: Erik] #1703061
11/27/14 12:07 PM
11/27/14 12:07 PM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
go get a holley 750-800 dp carb. bolt it on and hold on that'll wake it up.
Re: Too much Carb?? [Re: Erik] #1703062
11/27/14 12:17 PM
11/27/14 12:17 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
If throttle response at low rpm, clutch engagement, and street drivability are what you're really concerned with............it may not be the carb cfm, which is a little big, but more of a initial and total mech. advance issue to push on the motor with all that .050 duration and mildish 3.55 gearing.
What is your initial timing? Total? And then mech. advance is what I'm getting at?
A slow/soft advance makes many a carb seem too big.
I'd tweak the mech. advance and if you're still not happy drop down to a 750, then 700.
Re: Too much Carb?? [Re: Dean_Kuzluzski] #1703063
11/27/14 01:20 PM
11/27/14 01:20 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the total air flow isn't an issue; if you believe the advertised flow numbers. the issue for driving is going to be the large primary throttle bores/venturis, poor out of the box calibration and too large of an accelerator pump squirter. ignition recurve a must with that cam. it's all doable, if you have the knowedge/skills, but not ideal.
