Page 3 of 9 1 2 3 4 5 6 7 8 9
Re: FORD 8.8 REAR................ [Re: Quicktree] #1702564
11/26/14 07:41 PM
11/26/14 07:41 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The Buick we currently race in Drag Radial, had a 10 bolt under it when we bought it. The car had run 5.50s with small blocks when we bought it and our big block made it a 5.20 car right off the bat. We ran the 10 bolt until we broke it (which wasn't long). The point was, the car "evolved" from a streeter to a low 5 sec car and the 10 bolt was "good enough" to a point.......then it wasn't.........so in Dom's case, moving from an 8.75 TO an 8.8 under his car........well he may as well light that money on fire, because it will accomplish the same thing.
Monte
Just curious Monte, what rear is in that Buick?
Chromoly 9" sheetmetal Ford housing, with 40 spline gun drilled axles, alum Mark Williams center, with a 3.70 Pro gear and a billet 1350 yoke with a solid joint............expensive? yeah I guess, but high power, hard hooking radial cars will break EVERYTHING. Radial cars are harder on drive line parts by FAR than slick tire cars. That said, we have NEVER broken a single part in the rear...........Several radial guys I know this year were twisting and breaking 40 spline axles. That's how hard these cars can be on parts.
Monte
If thats the case, then move up to a Dana 70, 10.5" ring gear, 35 spline axles, 3.5 tubes with .5 wall thickness, looks like a 60 but on steroids inside! 1401 ujoints and a bunch of ratio's up to 7.17 to 1 Tim
Oh I love getting on here. Twisting 40 spline axles and should go back to 35 spline and add 150 lbs in the process. That is exactly what they should do. I think you should call all the big chassis shops and get them all on board with the dana 70 movement also. You better buy up all the parts they are going to be flying off the shelf.
heck I am heading to the junk yard today to see if I can find a dump truck rear to put in mine
Make sure you get the 2 speed axel, that will help your little SB
Re: FORD 8.8 REAR................ [Re: Quicktree] #1702565
11/26/14 08:53 PM
11/26/14 08:53 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
,looking to buy a new rear-end in the next week or 2, my factory 8 3/4 may not be up to the 535 stroker 6 pak,cope built 727 tranny, and the slicks, this is in my 70 runner,with the stroker expected to make 650 hp and 6?? torque, want to add a rear that will not fail me, as this is all new and i will being put together next month, thoughts were to buy a DANA (to stick with mopar)car will not be tubbed but inner wheel wells massaged for bigger meats. So in short a good read post
just a tip, Dana is not mopar. they came in just about all trucks. mopar used them because they knew the 83/4 wouldn't handle the big hemi's and 440s
Mopar knew some of you guys would set pinion angle wrong
Re: FORD 8.8 REAR................ [Re: Sport440] #1702566
11/26/14 09:28 PM
11/26/14 09:28 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
OH SNAP!
Re: FORD 8.8 REAR................ [Re: Quicktree] #1702567
11/26/14 11:36 PM
11/26/14 11:36 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
A good spot to find them is in old FORD trucks. It will make a great mopar rear nice and heavy.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: FORD 8.8 REAR................ [Re: 1967dartgt] #1702568
11/27/14 01:41 AM
11/27/14 01:41 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Forget that wimpy Dana 70, go for AAM GM corporate 14 bolt!
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: FORD 8.8 REAR................ [Re: DusterDave] #1702569
11/27/14 02:25 AM
11/27/14 02:25 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Are you talking the 3/4 ton chebby 14 bolt? Its about 20% weaker than the 70 and 35% less than a Dana 80. Rock crawlers bust them all the time....Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702570
11/27/14 04:39 PM
11/27/14 04:39 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
I know of lots of low 5s cars running 8.8s. Stock ring gear bolts suck.
I don't think it's a matter of who goes fast on an 8.8. it's a matter of if he's going to upgrade is that the best choice. I don't think it is, he would be better off doing it right the first time.
Looks like I`ll be gettin WHITEDART`s 9" after the M.A.T.S. unless it blows up or I find something sooner........ Time to step up................
Thump......you mean to tell me your giving up the 8 3/4 I thought we were the only 2 that would carry the 8 3/4 banner for life.....Lol
Re: FORD 8.8 REAR................ [Re: racerx] #1702571
11/27/14 05:06 PM
11/27/14 05:06 PM
State of confusion
Thumperdart Offline OP
State of confusion
So confused............. Not 100% sure on the 9 but I`m only going to make more power so I`d hate to scatter stuff and unless I can get to 2800 lbs. wet, I don`t see any other option.
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702572
11/27/14 08:11 PM
11/27/14 08:11 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
What are your plans to make more power?
Re: FORD 8.8 REAR................ [Re: Sport440] #1702573
11/27/14 09:16 PM
11/27/14 09:16 PM
State of confusion
State of confusion
I think I`m going to push the stock block a bit w/a Max Wedge top end and a bigger carb. It`s my goal which is $$$ limited at this point or it would already be done and I`d be posting my 9.30 time slips..............
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702574
11/28/14 02:36 PM
11/28/14 02:36 PM
dogdays Offline
dogdays  Offline
Torque breaks rear ends, not horsepower.
Sounds to me like your intended changes are going to move the peak of the torque curve up in the rpm range, but not increase maximum torque. Gear loading doesn't change.
Where horsepower would come into play is if you were running a top speed event and the increased engine power would be used making the car go faster. In this case, the energy being transferred by the rear gears would increase, increasing the heat load into the rear end. This is the reason that some circle track cars use coolers on the differentials.
R.
PS: There are (were) two GM 14-bolt rear ends, the light duty 9.5" ring gear and the heavy duty 10.5" ring gear.
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702575
11/28/14 05:33 PM
11/28/14 05:33 PM
Dom, with dollars amount spent for best results this is what you need, not some after markert Ford designed based power robbing piece Go to one of the local junk yards and buy a used Dana 60 housing with a bad end and have Jason cut and narrow it. Use a set of good 35 spline axles made to work with your brakes, I special orerded mine for my Duster from Strange , spool or posi, your choice and a good used set of Dana 4.10 gears
Re: FORD 8.8 REAR................ [Re: Cab_Burge] #1702576
11/28/14 05:44 PM
11/28/14 05:44 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I would get a jy dana 70, 40 spline axles and put ford ends on with explorer or crown vic brakes. 10.5 ring gear and no heaver than the 60....and it comes with .5 thick tubes. You could build this for about $900 if you get a deal on a housing with the gears you want.
I got my 60 for $75, it was 600 to narrow and shafts from Dutchman. Pick your locker/posi unit and gears, you may get lucky and get what you want from the yard.... Brakes were $80 for the explorer discs I got a 3.55 r&p for $55, real Dana, so with a little work you can get a real nice setup fairly affordable...that will be indestructible.
Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: FORD 8.8 REAR................ [Re: Cab_Burge] #1702577
11/28/14 05:48 PM
11/28/14 05:48 PM
State of confusion
State of confusion
I know a few who have built 60`s from scratch but I have no desire and am not fond of the look. I like backbraced rears under a car, less wt. and since Ferds are my second favorite cars, a 9" it is.
Re: FORD 8.8 REAR................ [Re: Thumperdart] #1702578
11/28/14 07:44 PM
11/28/14 07:44 PM
Q
Quicktree Offline
Quicktree  Offline
Q
smart move
Re: FORD 8.8 REAR................ [Re: Quicktree] #1702579
11/28/14 10:09 PM
11/28/14 10:09 PM
smart move
I've seen a lot more nine inch race type third members,using all non Ford components, being fixed at the NHRA National races by the traveling rear end professional guys than any Mopar type rear ends being fixed or swapped out To each thier own I remember when Jack Chrisman conned Jim Dunn and Joe Reath into being the guinney pig for his R&D on switching from the Olds, Pontiac and Mopar 8 3/4 rear ends in the old funny cars and top fuel cars to the nine inch Fords In todays world thier are no OEM Ford parts in any of the decent after market performing nine inch type rear ends, not even the housings I'm sure thier are reasons for most racers using them, not me I don't make enough power to break what I run now BTW, I can't afford them high dollar race parts like the race type Ford nine inch or 9.5 inch race rear ends anyways My 1940 Ford tudor street rod will have a Lincoln Versias 9 inch rear end in it with all the recommended good parts like a nodular third member and good aftermarkey front pinion support and maybe even a back brace, if Dom will pay for that part
Re: FORD 8.8 REAR................ [Re: Cab_Burge] #1702580
11/28/14 10:18 PM
11/28/14 10:18 PM
Q
Quicktree Offline
Quicktree  Offline
Q
sure you have because they out number truck rear ends about a million to 1 at any race track
Re: FORD 8.8 REAR................ [Re: Cab_Burge] #1702581
11/28/14 10:27 PM
11/28/14 10:27 PM
State of confusion
State of confusion
Don`t worry guys, I`ll do my best to grenade it next Sun. if I make the Fontana T&T..................
Re: FORD 8.8 REAR................ [Re: astjp2] #1702582
11/28/14 10:28 PM
11/28/14 10:28 PM
gregsdart Offline
gregsdart  Offline
Tim
Well, not indestructible, but it will take quite a beating !
I ran a 4.10 geared stock Dana with a clutch type posi, shimmed so the clutch packs were locked solid. Wulla! instant cheap spool! That and a pair of spring perches, and axle ends to weld on and you are ready to go. The drive shafts might inter change as well or need a cross over joint. If the clearance is a little tight to the tranny a few shims behind the spring hangers take care of that.
Dom, I doubt I changed your mind, but posted this for those who might need a poor mans rear end swap! Hope you find exactly what you want!
Re: FORD 8.8 REAR................ [Re: gregsdart] #1702583
11/28/14 11:37 PM
11/28/14 11:37 PM
State of confusion
State of confusion
I`m still thinking openly about it but this 9 deal is sweet.............
