Page 1 of 4 1 2 3 4
Best gas mileage with 360? #1701938
11/22/14 09:18 PM
11/22/14 09:18 PM
Kingston, TN
CudaMike Offline OP
super gas
CudaMike  Offline OP
super gas
Kingston, TN
What is the best gas mileage that anyone has got with a 360?
Re: Best gas mileage with 360? [Re: CudaMike] #1701939
11/22/14 09:31 PM
11/22/14 09:31 PM
Oakdale, MN
W
weazel Offline
weazel  Offline
W
Oakdale, MN
11.6 with mine..
71 Scamp, 727, 3:73 gears, xe268 cam and air gap.
Re: Best gas mileage with 360? [Re: CudaMike] #1701940
11/22/14 09:39 PM
11/22/14 09:39 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The 360 seems to have a bad rep for being thirsty.
A few years ago one of the guys did an in-depth build to maximize economy and torque using a 360. I'm not sure if it's in the archives. He might pop in here.
You failed to mention the type of vehicle and it's intended purpose.
- Stu Harmon
Re: Best gas mileage with 360? [Re: feets] #1701941
11/22/14 09:47 PM
11/22/14 09:47 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
Quite relevant. Are we talkin' about putting it in a Neon, or an early 70's 4X4? I've seen folks on this forum speak of getting 318's into the 20 mpg range. Not sure why a purpose-built 360 couldn't do similar...depending on the application.
Re: Best gas mileage with 360? [Re: Fat_Mike] #1701942
11/22/14 09:53 PM
11/22/14 09:53 PM
Kingston, TN
CudaMike Offline OP
super gas
CudaMike  Offline OP
super gas
Kingston, TN
I'm considering a F-body with 360 and was wondering what the potential is. I know from doing some research already that almost everyone gets poor GM. I have to wonder why they don't do better than they do from an engineering viewpoint.
Re: Best gas mileage with 360? [Re: CudaMike] #1701943
11/22/14 10:06 PM
11/22/14 10:06 PM
N.W. Florida
N.W. Florida
I was thinking of this thread, and and should have posted the link in my last response. While it may not answer your question in its entirety, there's good insight here:
https://board.moparts.org/ubbthreads/show...rue#Post8268340
Re: Best gas mileage with 360? [Re: Fat_Mike] #1701944
11/22/14 10:31 PM
11/22/14 10:31 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Had an 87 M body with a 360 and an A833 four speed. 2.94 SG 8 1/4 in back. If I kept it to 65 mph and didn't get on the gas I could get low 20's highway. The 360 was very mild, XE262 cam, 302 heads, Edelbrock 1406 carb, Performer intake, MP electronic ignition. When the M had a 318 it'd get mid 20's highway.
Don't be the exception.
Re: Best gas mileage with 360? [Re: CudaMike] #1701945
11/23/14 01:06 AM
11/23/14 01:06 AM
South East Ontario, Canada
Ramtough Offline
Ramtough  Offline
76 Power Wagon,360,Auto,650 holley,air gap intake,3:55 gears with 35" tires, 55-60 mph, gets 19.5 mpg.
Had 76 Cordoba 20 yrs ago, stock got 27 mpg on highway
Re: Best gas mileage with 360? [Re: Ramtough] #1701946
11/23/14 01:15 AM
11/23/14 01:15 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
I get 17-18 on the highway with mine in the W350. 360 with KB107 pistons and Crower Baja Beast cam, 4.10 gears and A518 trans. That is rolling at 65mph, going from 5200' to over 11000' at the top of Eisenhower and Vail passes. Putting in the overdrive added a ton of mileage compared to when it had only the 727. Haven't been able to check it on flat land only yet. I have the AFR set to run right at 14.7:1 and it will hold it dead on. In a lighter and more aerodynamic vehicle, I don't see why it wouldn't easily top 20.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: Best gas mileage with 360? [Re: herkamer] #1701947
11/23/14 01:38 AM
11/23/14 01:38 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
1994 D2500 Long Bed 360 Magnum ....8800 lbs Gross Vehicle Weight Truck...basically one ton truck without the dually in the back..
at 70 mph it get 19 miles a gallon...
the Truck has 315,000 miles on it...as for the engine I dont know..but it sounds like it has a slight miss at idle.
Tony
70 AARCuda Vitamin C
Re: Best gas mileage with 360? [Re: herkamer] #1701948
11/23/14 01:10 PM
11/23/14 01:10 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Going with a moderate rear gear will improve acceleration and economy in city traffic. Stuffing an OD behind it will greatly improve highway mpg.
- Stu Harmon
Re: Best gas mileage with 360? [Re: feets] #1701949
11/23/14 10:35 PM
11/23/14 10:35 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
In 76 I bought a new Aspen RT with a 360 2bl, I swapped intakes and put an LD 340 and a 650 Holley, and dual exhaust (no Cats).. Highway only mileage was high teens, near 20 MPG.. it had a tall gear...2:45 I think..
Re: Best gas mileage with 360? [Re: CudaMike] #1701950
11/24/14 02:58 AM
11/24/14 02:58 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
It's not possible with mine! 2001 Ram QC 4x4 off-road package.5.9,auto w/overdrive 4.10 gears. Generally around 10 mpg average. 8.8 avg on a 3k mile round trip with a motorcycle trailer.It got 14.6 on a 500 mile trip once,...once.
Re: Best gas mileage with 360? [Re: 70AARcuda] #1701951
11/24/14 03:10 AM
11/24/14 03:10 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Towing a 71 Duster on a flat bed trailer with steel deck, plus the bed full of stuff...going from Vegas to Bakersfield back in Oct...
Truck got 14.5 mpg
Tony
Re: Best gas mileage with 360? [Re: 70AARcuda] #1701952
11/25/14 12:50 PM
11/25/14 12:50 PM
Earth
Rob C Offline
Rob C  Offline
Earth
A 360 in my 3700+ lbs. '79 Dodge Magnum would get 20 MPG's.
OE '79 - 360 backed by a 904 & 2.76 gears w/245/60/15's
Fed-Mogual 625 AFB
'73 trap door air cleaner & K&N filter
OE iron 4bbl.
A used truck vacuum advance distributor
MSD 6A
Dual exhaust @ 2-1/4 with twin cats (law required at the time)
and an "H" pipe off the exhaust manifolds.
Tune tune tune tune tune!!!!!
Re: Best gas mileage with 360? [Re: feets] #1701953
11/25/14 01:50 PM
11/25/14 01:50 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Going with a deeper gear (3.55 or 3.91) and a 518-OD I haven't been able to improve my mpg on my '73 Dart as opposed to its earlier 318/904/7-1/4" setup.
IMO biggest problem is that 90% of my daily commutes are 10-15 minutes max, so I'm pretty much always driving with a cold engine and drivetrain which robs a lot more power.
Best results improving the mpg was accomplished with engine tuning. This was shortly after I just bought the Dart where I was able to about double the mpg from about 8 to 17 mpg (highway).
Re: Best gas mileage with 360? [Re: BigBlockMopar] #1701954
11/25/14 07:19 PM
11/25/14 07:19 PM
Chicago suburbs
dartgame Offline
dartgame  Offline
Chicago suburbs
73 plymouth gran fury 2 door. 75 360 engine - stock 340 cam, TQ, 340 intake, stock pistons, single exhaust, 245 rear end. 24 mpg crusing at 70. Same motor in a 75 coronet 2 door, 2.76 rear end, 26 mpg cruising on hwy. The big part obviously is the rear end gearing. I've always found 360s to be good on mileage when built conservatively. The TQ is a great economy carb as well.
Re: Best gas mileage with 360? [Re: dartgame] #1701955
11/26/14 12:28 AM
11/26/14 12:28 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Dartgame, what size tire and was it a lock up trans?
Re: Best gas mileage with 360? [Re: Rob C] #1701956
11/26/14 01:12 PM
11/26/14 01:12 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
1974 Duster360 with original 360 & TQ, 727 auto, 2.45:1 rear end, 235/60/14 tires, . . .cruising at 70mph, engine ticking over at 2500RPM, MPG usually 24mpg ! The 360 has more than enough low end grunt to roast the right rear tire !! . . .
Cheers,
Re: Best gas mileage with 360? [Re: a12rag] #1701957
11/26/14 07:09 PM
11/26/14 07:09 PM
P
Paul_Fancsali Offline
P
My E-58 with 3.91s and or 4.30s got avg of 11 with short tires 25 inch and holding 3500 to 4000 never better but never worse part of game I guess. Example raced 2 Saturdays ago and drove the car 110+ miles ran over 14 passes some round robin and only used 11.6 gallons Ran the car threw the lights to 105 to blow it out Carb 650 Dbl Pumper Holley
Page 1 of 4 1 2 3 4
