Re: Fuel filter?
[Re: 383man]
#1701801
11/25/14 12:04 AM
11/25/14 12:04 AM
Posts: 43,368 Bend,OR USA
Cab_Burge
I was told years ago a Micron was one millionth of a inch, not sure if the was a sqaue inch, cubic inch or linear inch ![](/ubbthreads/images/graemlins/confused.gif) Way smaller than the average eyes can see ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) I ended up using a #10 combination fuel shut off and in line fuel fiter that was rated at 80 micron on my Duster between the pump and the gas tank sump, I should have bought the 100 micron size according to Mganafuel ![](/ubbthreads/images/graemlins/shruggy.gif) My new car will have that size filter rating in a 12 AN in line fuel filter with as much surface area and as long as I can get it ![](/ubbthreads/images/graemlins/thumbs.gif) I put the Duster together with a BG 500 in line fuel filter, it had a 10 micron fuel filter in it and it did starve the Magnafuuel 275 pump I bought new for that car ![](/ubbthreads/images/graemlins/image_294343.gif) Live and learn ![](/ubbthreads/images/graemlins/shruggy.gif)
Re: Fuel filter?
[Re: markz528]
#1701803
11/25/14 11:34 AM
11/25/14 11:34 AM
Posts: 361 Canada
onig
Canada
1 micron = .000,039,37" 10 micron = .000,393,7" 100 micron = .003,937"
1 micron = 1 millionth of a Meter
69 Dart
Re: Fuel filter?
[Re: Dodgeguy101]
#1701804
11/25/14 11:42 AM
11/25/14 11:42 AM
Challenger 1
Cincinnati, Ohio
Cant remember who I called to ask about that filter, but I was told it couldn't handle the output of that black pump. Get a different filter type. Mine is noisy as well, but I got a good deal on it, so for the time being, its on the car.
That's BS. That fram filter is made to go after the pump and can easily handle a black pump discharge volume. All filters are made to go after the pump. Please don't be one of those geeks who have the pump and filter hanging out the back of your car for everyone to see with the filter between the tank and pump showing everyone you don't know how to plumb a fuel system. Like Cab said...and you know now.
Use a AN fitting in the tank with a cone shaped stainless strainer built in and no other restrictions before the pump. Only a strainer with 100 micron screen or courser should be in front of the pump. Even a strainer housing creates turbulence in the fuel flow. And the inlet plumbing to the pump should be larger than the discharge plumbing with very little restrictions(like least amount of 90, 45s and no filters)
The reason pumps are noisy is because they are screaming for help, cavatating there brains out and dieing a slow death. Warmer the weather get's, the more important that the fuel inlet plumbing is right.
Next time I have a question, I wont call anyone but you, because you seem to be a know it all. This kind of an answer is exactly why people don't say anything anymore or offer advice. You have no idea what fuel system is on my car.
Well I seem to be the fastest and quickest guy on this board and have built 6 real fast cars including the fuel systems. How fast have you gone with your fuel system?
I know my way around fuel since I have been in the fuel business for over 30 years now.
And I didn't post anything backwards or wrong above.
It don't matter what kind of car you have, fuel basics apply to every car. \ Lastly I don't consider a strainer to be a filter, it's a strainer to protect the pump. The filter which is finer goes after the pump to protect everything after the pump.
Re: Fuel filter?
[Re: Challenger 1]
#1701805
11/25/14 12:58 PM
11/25/14 12:58 PM
Jerry Kathe
I know my way around fuel since I have been in the fuel business for over 30 And I didn't post anything backwards or wrong above.
Thanks for making me spew coffee all over my screen - ![](/ubbthreads/images/graemlins/coffeetime.gif)
Re: Fuel filter?
[Re: Jerry Kathe]
#1701806
11/25/14 01:15 PM
11/25/14 01:15 PM
Challenger 1
Cincinnati, Ohio
OK...you asked. Not going to debate this one either .....but.....micron rating has absolutely nothing to due with flow capabilities when discussing fluids with the viscosity levels of fuel.
Micron rating with filters is referring to particulate size its capable of trapping.....and with fuel the smaller the number the better......and before the pump....no true racing quality level of electric fuel pump will make debris.
Not looking for a rumble....only trying to help. If I wasn't kicked back on vacation right now....I would probably not have bothered as I know this will stir the key board warriors
This post really tells me you do not know fuel pump plumbing. Ever heard of cavitation? ![](/ubbthreads/images/graemlins/biggrin.gif)
Can you show us where any fuel pump manufacturer says to use a filter with "the smaller the number the better......and before the pump" filter?
They all say strainer or screen element.
Re: Fuel filter?
[Re: Jerry Kathe]
#1701808
11/25/14 01:53 PM
11/25/14 01:53 PM
Challenger 1
Cincinnati, Ohio
I have no interest in persuading anyone of anything. I attempt to clairify my statements are that of my opinion. My opinion is based on my experience.
I havent spent money on HP in quite some time....largely because I dont care about being the fastest or quickest at the track or on some technical forums. But might I suggest not undermining someone's/anyone's knowledge by how much money they spend.
I will throw this out there....go visit the pro stockers camps and tell anyone of them they are doing it all wrong with their fuel system configurations.
I don't have to visit pro stocks, because all 6 of my cars are were faster than pro stocks. I move more fuel than they do. And I still have 2 cars and 2 BAE hemis 6' behind me right now.
Re: Fuel filter?
[Re: Thumperdart]
#1701810
11/25/14 02:23 PM
11/25/14 02:23 PM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
I have the quickest and fastest car on my street.............PERIOD.........AND I plumb my own fuel system all by myself and even read the directions...
Hey, same here, but play the bagpipes instead of drums. ![](/ubbthreads/images/graemlins/wave.gif)
I used RobbMc 40's before and after the pump based on his directions.
"40 Micron Filters - Designed for use as prefilters for gerotor style electric fuel pumps. Also used to filter fuel before it enters the carb."
Re: Fuel filter?
[Re: Mopar_Ray]
#1701813
11/25/14 03:39 PM
11/25/14 03:39 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
Reference from the back of the Holley fuel filter packaging.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Fuel filter?
[Re: Dodgeguy101]
#1701814
11/25/14 04:22 PM
11/25/14 04:22 PM
Challenger 1
Cincinnati, Ohio
The reason people like me don't answer questions is because of people like you.
Re: Fuel filter?
[Re: RT540]
#1701816
11/26/14 12:45 AM
11/26/14 12:45 AM
Posts: 515 geezer acres rest home
dakotawilly
my pro stock coffee maker pumps .7 gpm.now if i put the filter before the pump,i will have to invest in toothpics to retrieve the coffee grounds from my teeth.so ill just keep the filter after the pump.and may even send it over to monte to have it plumbed for nitrous to make my mornings even brighter....
SFI 25.5 depends,no leak,even at 213 mph....
Re: Fuel filter?
[Re: Challenger 1]
#1701817
11/26/14 01:47 AM
11/26/14 01:47 AM
Posts: 10,563 Rittman Ohio
fourgearsavoy
Rittman Ohio
Boy do I feel like a geek ![](/ubbthreads/images/graemlins/eyes.gif) I think I might just switch the positions and clip my ET from 10.91 to maybe 10.50 ![](/ubbthreads/images/graemlins/shruggy.gif) I thought I was doing pretty good with a 3600# car and 3.54 gears ![](/ubbthreads/images/graemlins/bump.gif) I'll change it tomorrow and wait unti spring and try it out. Thanks Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Fuel filter?
[Re: Cab_Burge]
#1701819
11/26/14 08:00 PM
11/26/14 08:00 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
1970-71 Pro Stock cars were running 9's with pumps and filters that alot of people say are no good today.
