RamCharger Tank in a truck
#1701605
11/21/14 11:05 PM
11/21/14 11:05 PM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
After cranking my 85 ShortBed & letting it run a while I decided to make a block & it died at the gate before hitting the street with the pickup in the tank clogged up Not having a spare & having plans for doing a RamCharger tank anyway I snatched the bed & started grinding & cutting rivets Here's a before & here's where I stopped this evening While having the bed off I took advantage of the bed being off & whacking at rivets I decided to do a little leveling so I lowered it 3" in the rear for the cheap
Re: RamCharger Tank in a truck
[Re: BulletBob]
#1701606
11/22/14 12:55 AM
11/22/14 12:55 AM
Posts: 16,813 Between Houston & Galveston TX
SattyNoCar
I did the tank swap on a '76 Club Cab I used to own 20+ yrs ago.... The only fitting issue I ran into was a channel on the bottom of the bed wanted to share the same space with the 'new' front crossmember. The truck rode so much better with all that weight being behind the axle and centralized. Made running duals a snap too.
John
[Re: SattyNoCar]
#1701607
11/22/14 01:02 AM
11/22/14 01:02 AM
BulletBob
Back home in PA
I ran into that on my old 87 Lwb D150 Eventually it will get a aluminum fuel cell sunk in the bed but this will do for a while This is the tank I'll be putting in it has a #6 pickup tube & 5/16 return
[Re: 76dodgeboy]
#1701609
11/22/14 04:07 AM
11/22/14 04:07 AM
BulletBob
Back home in PA
I wonder if its the same issue with a Shortbox? I plan to do the RC Tank in a couple trucks.
I'll know tomorrow
[Re: BulletBob]
#1701611
11/22/14 09:28 AM
11/22/14 09:28 AM
Posts: 5,961 Greenville, PA
redraptor
Greenville, PA
I'll know tomorrow
The factory rear tank and crossmember must be different than an RC.
[Re: redraptor]
#1701613
11/22/14 01:01 PM
11/22/14 01:01 PM
BulletBob
Back home in PA
I'll know tomorrow
My old dually had a rear tank that seemed to sit lower in the frame than the RC tank does
[Re: redraptor]
#1701620
11/23/14 03:38 AM
11/23/14 03:38 AM
BulletBob
Back home in PA
I'll know tomorrow
The Shortbed crossmember is in the same exact spot as the RamCharger
Look where it sits on the frame
