Re: Do you run tubes in your slicks? [Re: bobs69] #1701594
11/23/14 12:10 PM
11/23/14 12:10 PM
Jerry Kathe Offline
Jerry Kathe  Offline
9 out of 10 bracket racers wouldnt see the difference either way. Tubes can help stiffen the tire sidewall for pro tree racing....but not using tubes does save money and do lighten the wheel/tire package if absolute low ET and peak mph is that important to you ...but it would be very negligible.
Re: Do you run tubes in your slicks? [Re: Jerry Kathe] #1701595
11/23/14 02:05 PM
11/23/14 02:05 PM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
MT slicks with tubes here too!
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Do you run tubes in your slicks? [Re: Ari440] #1701596
11/23/14 02:23 PM
11/23/14 02:23 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
M/T slicks with tubes
I also have 8 screws per side to hold the tire on
if you where to double the screws per side would it help
poor mans beadlock
1.39 9.85 - 137 mph
Re: Do you run tubes in your slicks? [Re: bobs69] #1701597
11/23/14 02:38 PM
11/23/14 02:38 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I am running Good Years without tubes. I put the Dawn dish washing liquid inside, but apparently not enough, as they do slowly loose air pressure in a few days.
We are foot braking only, if that matters?
The tires are not pinned, but they have not moved at all so far.
When I was buying the tires and wheels, the people I asked were not using tubes, so I went that way. In the past I always used tubes, but I had not raced in many years, and some things are done differently these days.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Do you run tubes in your slicks? [Re: Hemi Allstate] #1701598
11/23/14 09:24 PM
11/23/14 09:24 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
Hoosier, tubeless with screws...
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Do you run tubes in your slicks? [Re: Dartsport540] #1701599
11/23/14 10:12 PM
11/23/14 10:12 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
For what it's worth I put 155 passes on my 10.5W x 31 M/T w/o tubes or screws. At the end the 60's fell off about from 1.32-1.33 to 1.35-1.36 on average, but were still consistent. I don't run screws. The tires turned 180 degrees during the first 30 passes, then settled down.
Doug
Re: Do you run tubes in your slicks? [Re: bobs69] #1701600
11/24/14 06:36 AM
11/24/14 06:36 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Something people never consider is that sometimes the air loss isn't porosity in the sidewalls - it's actually a bead leak from the low tire pressures not seating the beads.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Do you run tubes in your slicks? [Re: Evil Spirit] #1701601
11/24/14 11:14 AM
11/24/14 11:14 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Like i said I don't use tubes but I seal them twice with Dawn dish soap and water BUT I also don't use screws. I seal the tire to the rim with High Tack Gasket spray. Some guys that use screws forget about upping the tire pressure when they screw the slick to the rim and actually push the slick away from the rim creating an air-leak.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Do you run tubes in your slicks? [Re: pittsburghracer] #1701602
11/24/14 11:20 AM
11/24/14 11:20 AM
PA.
"Little"John
"Little"John
PA.
--------------- From the Mickey Thompson website tech--------------------
PROPER INSTALLATION OF RIM SCREWS WITH TUBE TYPE TIRES
1. Begin by drilling 12 equally spaced holes on both the inner and outer flange of the rim. See the diagram 4-A below.
Note: (Mickey Thompson strongly suggests that you use Drag slick mounting screws only, and that you follow the rim screw manufacturers suggested drill bit size.)
2. Trial run the screws through all 24 (32) holes. Running screws in the hole and back out again. A dab of grease on the screw will help.
3. Check for any sharp edges that the screw may have pushed out or caused during the trial run through. If any sharp edges are found de-bur and make sure the inner bead flange of the rim is smooth and clean.
4. Mount tire and tube. Have an experienced professional install the tire and tube on proper equipment. (Refer to Mickey Thompson Tech Bulletin #2 for tube mounting procedures and Mickey Thompson Tech Bulletin # 8 for proper procedures to check rollout (circumference).
5. Before installing the screws, inflate the wheel and tire assembly to 20 psi. Put a small amount of grease on each screw and install into wheel and tire assembly. Deflate assembly to operating pressure. Inspect rim flange and bead area for proper bead seating. If bead is not fully seated, re-inflate and reinstall screws.
6. For best results, static balance or "Bubble Balance" the assembly once screws are installed.
7. Periodically you should check the wheel for loose screws and inspect the rim bead area to be sure that there is no bead area separation.
Note: It would be good practice to inspect after each pass when you are checking your air pressure.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Do you run tubes in your slicks? [Re: pittsburghracer] #1701603
11/24/14 11:23 AM
11/24/14 11:23 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I ran Mickeys on the Duster tubeless and Goodyears with tubes. I run tubes in the Arrow in the Hoosiers for reaction time. I personally like a stiff sidewall and the tires seem to last quite a bit longer.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Do you run tubes in your slicks? [Re: Eric] #1701604
11/29/14 05:03 PM
11/29/14 05:03 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
hoosier 10.5x30" no tube soap inside and they hold air like tubes are in. tires are screwed to the rim.
