Do you run tubes in your slicks? #1701574
11/21/14 11:02 PM
11/21/14 11:02 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
I run Hoosier 32x14 slicks now with no tubes. Thinking of buying mickey Thompson this time because they are cheaper. The Mickey Thompson say to run tubes. Do I need tubes? Do you run tubes in your Mickey Thompson slicks? Thanks
Re: Do you run tubes in your slicks? [Re: bobs69] #1701575
11/21/14 11:21 PM
11/21/14 11:21 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I do not run tubes in my M/Ts. Have run 10.5x28W, 10.5x29.5, 10.5x31W. They leak through the sidewalls. Soaping the inside of the side wall slows it down pretty good. I don't screw them to the rims. Plus I can plug one if it hits a screw or a nail. 60 fts seem pretty consistent, low 1.30s.
Doug
Re: Do you run tubes in your slicks? [Re: dvw] #1701576
11/21/14 11:24 PM
11/21/14 11:24 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
x2
Re: Do you run tubes in your slicks? [Re: a493demon] #1701577
11/21/14 11:33 PM
11/21/14 11:33 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Tubes help stiffen the sidewall.......which is never a bad idea, plus they don't leak
Monte
Re: Do you run tubes in your slicks? [Re: bobs69] #1701578
11/22/14 12:02 AM
11/22/14 12:02 AM
I bougt a set of M/T 14x32x15 stiff side walls last year from Summit is Sparks, NV on the way to the MATS race in Las Vegas this year in April. My car had a set of Goodyear 16x33x15 that had been on the car for over 6 years before I bought it and I could see the cords on the sidewalls breaking on the sides at the max section width, they where ran tubeless on the 15 inch wide rims with a bunch of rim screws and had a bunch of rubber left on them according to the wear dots I ran them at the big Spring Fling 4 day bracket race the weekend before the MATS race. I had the local Goodyear race tire warehouse mount my new M/T after that race, I tried to buy tubes from them and they told me that they hadn't sold or had race inner tubes or inner liners in over 5 yrs My M/T where no slower or faster than them old Goodyears No tubes in them yet, no soap either yet Probally take them off the rims this winter and soap them rascals up and try again IHTHs My car weighs 2750 with me in it, best 60 ft. so far has been 1.27 off the trans brake
Re: Do you run tubes in your slicks? [Re: Monte_Smith] #1701579
11/22/14 12:13 AM
11/22/14 12:13 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I've been racing since the 60's and never ran over a screw or nail, I even drove for a few years with slicks on the street. Must be lucky. Back to the tubes. Usually I start out without tubes, soap up the insides real good but when the side walls start leaking it's time to put in the tubes. I just have a low 10 bracket car so it really doesn't matter if I do lose a couple .000 One thing I have found is the proper install of the tubes. If you have ran the slicks soaped up you need to totally get all the soap residue from inside the tire. Buy tire talc or baby powder and cover the tube and inside of the tire to keep the tube from sticking, if it sticks it rips.
Re: Do you run tubes in your slicks? [Re: Cab_Burge] #1701580
11/22/14 12:21 AM
11/22/14 12:21 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Look on the Harlow Tire website. They are one of the largest Goodyear distributors in the country. Their site tells you what part number tube you need for any size Goodyear tire.
Monte
Re: Do you run tubes in your slicks? [Re: Monte_Smith] #1701581
11/22/14 12:39 AM
11/22/14 12:39 AM
Monte
I wonder if there Goodyears or some other brand of race tubes? M/T sales tubes still, but not the west coast Goodyear tire race warehouse(use to be Carrol Shelbys place) and the race tire dealer at the races on the west coast
Re: Do you run tubes in your slicks? [Re: Monte_Smith] #1701582
11/22/14 12:39 AM
11/22/14 12:39 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
M/T slicks with tubes
1.39 9.85 - 137 mph
Re: Do you run tubes in your slicks? [Re: Ari440] #1701583
11/22/14 12:46 AM
11/22/14 12:46 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
No tubes in my Hoosiers and they hold air real good. I had M/T slicks some years back and had to run tubes with them as they leaked air very fast. Ron
Re: Do you run tubes in your slicks? [Re: Monte_Smith] #1701584
11/22/14 12:42 PM
11/22/14 12:42 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Monte
This
69 GTX 68 Road Runner
Re: Do you run tubes in your slicks? [Re: JERICOGTX] #1701585
11/22/14 01:10 PM
11/22/14 01:10 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Monte
This
"This" is a confusing statement. The soft flexible sidewall of the slick is designed to absorb the hit at the starting line and prevent spin. Enlighten me......
I have not run tubes for decades, for reasons:
1. Expense (I'm cheap)
2. Increase weight
3. If you have a puncture at the track just plug the tubeless. If you have tubes you are likely headed home.
Re: Do you run tubes in your slicks? [Re: AAR-B4] #1701586
11/22/14 01:27 PM
11/22/14 01:27 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
I have always run tubes because I have an ancient set of Cragar Super Tricks on my car and I would be concerned about leakage through the rim halves. The tubes were bought from Hoosier, they have the brass threaded stem with a locknut to secure them to the wheel. I also agree with the above statement from AAR-B4, especially #1.
Re: Do you run tubes in your slicks? [Re: bobs69] #1701587
11/22/14 03:46 PM
11/22/14 03:46 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Phoenix tires with tubes.We have always used tubes.Tire sidewalls also last longer using them.
Nautilus Racing-
Re: Do you run tubes in your slicks? [Re: AAR-B4] #1701588
11/22/14 05:08 PM
11/22/14 05:08 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Monte
This
2. Increase weight
You will beat the sidewall out of a slick well before you wear the tread out in most cases. The tube helps stiffen the sidewall, which will keep you from "crushing" the tire at the hit, which is what kills the sidewalls.
And even though guys do it ALL the time........NO tire maker suggests that you put a plug in a slick. I know I never would
Monte
Re: Do you run tubes in your slicks? [Re: Monte_Smith] #1701589
11/22/14 05:19 PM
11/22/14 05:19 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I always run tubes in my M/T drag slicks but in my street drag radials I run tubeless. My stick car seems to hook better with tubes
Gus
64 Plymouth Savoy
Dana 60
Re: Do you run tubes in your slicks? [Re: fourgearsavoy] #1701590
11/22/14 05:43 PM
11/22/14 05:43 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I always run tubeless and coat the inside sidewalls twice with Dawn soap and water. No leakage issues here and I must not hit my tires as hard as some of you guys as I run them till they are shot. 1.20 sixty ft times in my Daytona and 1.34's in my small block Duster. I never raced a car weighing more than 3000 ponds so that may help too.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Do you run tubes in your slicks? [Re: pittsburghracer] #1701591
11/22/14 05:51 PM
11/22/14 05:51 PM
Iowa
coronetville Offline
Iowa
Re: Do you run tubes in your slicks? [Re: Monte_Smith] #1701592
11/22/14 07:59 PM
11/22/14 07:59 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Monte
Re: Do you run tubes in your slicks? [Re: bobs69] #1701593
11/23/14 02:42 AM
11/23/14 02:42 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Tubes in my slicks? Yep always.
