hemi valve lash #1701545
11/21/14 08:48 PM
11/21/14 08:48 PM
r.i.
stuman Offline OP
stuman  Offline OP
r.i.
Have the motor out on my 69 RR. Wanted to check the vavle lash , can't fine what the clearence is on a 69 Hemi solid lifter setup , all stock. Any ideas on where to find that info. Thanks
Re: hemi valve lash [Re: stuman] #1701546
11/21/14 08:57 PM
11/21/14 08:57 PM
California
mickm Offline
mickm  Offline
California
.028/.032 cold.
Re: hemi valve lash [Re: stuman] #1701547
11/21/14 11:00 PM
11/21/14 11:00 PM
Stu welcome aboard . For a .032" gap if a .031" feeler gauge has no drag and a .033" gauge has a slight drag that is as close as you can get (with feeler gauges). A dial indicator type gapper would be the best & reportedly a few tho difference in the gap has a significant impact on changing valve timing but this was decades ago & iirc it was in conjunction with an ad for a P&G valve gapper which is a dial indicator type valve gapper
Re: hemi valve lash [Re: RapidRobert] #1701548
11/22/14 12:19 AM
11/22/14 12:19 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
http://www.ctci.org/gilsgarage/ValveGapperInstructions.php
I too remember them. Would make a solid lifter engine sound as a well tuned sewing machine when all valves were perfectly dialed in. The best solution for worn rockers.
A bit messy with engine running. In those days, did not seem as big a deal as now.
Don't know if had a kit for Hemi engines. Each engine required proper adapters.
Would be just the ticket for our 300 B.. However must pull generator/power steering pump combination to remove driver side valve cover,,,then re-install to start engine for adjustment of valves with engine running,,,could skip this re-install I suppose and idle engine with belts(there are 2 on dual groove generator/PS pulley) left off.
http://www.ebay.ca/itm/VTG-1956-P-G-Valv...2cc1&_uhb=1
