Where to purchase leaf springs? #1701392
11/21/14 01:49 AM
11/21/14 01:49 AM
Ball Ground, Georgia
Dixie Offline OP
Dixie  Offline OP
Guys,
Where are some places to purchase leaf springs? I need a stock replacement set for my son's Demon. Doesn't have to be correct, just work. I know of ESPO and Eaton. Anywhere else I should check? He's on a high school budget, so I'm looking for bang for the buck here.
Thanks!
Randy
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Where to purchase leaf springs? [Re: Dixie] #1701393
11/21/14 01:56 AM
11/21/14 01:56 AM
JR spring (jcwhitney of chicago). EDIT A (very likely) cheaper alt would be to dissassemble em & have a local spring shop rearch the main leaf(s) then you reassemble. Measure the bumper height to ground right now then jack it up till you get the height you want then measure the difference & give that number to the shop. MORE EDIT If you do order tailor made ones get em with 1" more arch (height) than stock
Re: Where to purchase leaf springs? [Re: RapidRobert] #1701394
11/21/14 02:50 AM
11/21/14 02:50 AM
None
71rm23 Offline
71rm23  Offline
None
Randy. Got mine from Spring n Things. They have them in stock height or +1, or+2 inch over stock height
Re: Where to purchase leaf springs? [Re: Dixie] #1701395
11/21/14 06:25 AM
11/21/14 06:25 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
John R spring in these parts...
Re: Where to purchase leaf springs? [Re: Dixie] #1701396
11/21/14 10:24 AM
11/21/14 10:24 AM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
Here's a second for Springs & Things . I had a pair of springs re-arched by a local spring shop and it only lasted a year.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Where to purchase leaf springs? [Re: Hrtbkr] #1701397
11/21/14 10:28 AM
11/21/14 10:28 AM
Stroudsburg, PA
Erik Offline
Erik  Offline
Stroudsburg, PA
I get all of mine from Springs and Things. My last set I picked up right at their shop. They told me I was the first customer to ever show up to pick up a set. LOL
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Where to purchase leaf springs? [Re: Erik] #1701398
11/21/14 11:39 AM
11/21/14 11:39 AM
Dixie Offline OP
Dixie  Offline OP
Thanks guys. I've asked Springs n Things for a quote. I have spring helpers on it now, but they're not quite working anymore.
Re: Where to purchase leaf springs? [Re: Dixie] #1701399
11/21/14 12:35 PM
11/21/14 12:35 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Springs n things X5
Re: Where to purchase leaf springs? [Re: TJP] #1701400
11/21/14 03:56 PM
11/21/14 03:56 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Do you have a spring shop around?I got a pair from local spring shop for my 57 that were on their shelf.Mine were totall broke.Cast me 200 bucks.My kid had them rearch his 62s and add a leaf and was like 120.They are still better than a new spring and been on for 15 years.Rocky
Chrysler Firepower
Re: Where to purchase leaf springs? [Re: Dixie] #1701401
11/21/14 05:59 PM
11/21/14 05:59 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Thanks!
Randy
Well, I'd ask if you are sure they need replaced, first. I've seen many guys think a mopar spring set should have a nice arch to them and they replace their "worn out" springs only to find the replacements sit nearly as flat. Mopar sprigns are designed to only have a couple of inches of arch to them when installed.
If they really are worn, get a set from the junkyard, cut the eyes off the main leaf to sit just under the eyes of his leaf spring pack, install in his pack. Results in a slight lift with a step up in rate. Net cost may be around $10-20.
Re: Where to purchase leaf springs? [Re: TC@HP2] #1701402
11/21/14 07:04 PM
11/21/14 07:04 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
You likely have a local spring shop that rebuilds springs for trucks. If your main leafs are OK, you might be money ahead to rebuild your current springs. Depends on the spring shop. The spring shop we have here is cheaper then I can buy springs online and get them shipped to me. Our local guy bends U bolts too. Gene
Re: Where to purchase leaf springs? [Re: poorboy] #1701403
11/21/14 08:35 PM
11/21/14 08:35 PM
Compress the spring on either side of the middle bolt with a pair of C clamps then remove the nut with a nut cracker. Most times the nut is rusted and or the threads are fubared & if you try to uncrew the nut you'll snap the shaft & that is a special bolt. Chase the threads & a new grade 8 nut loctited & that situation is dealt with
Re: Where to purchase leaf springs? [Re: RapidRobert] #1701404
11/21/14 08:56 PM
11/21/14 08:56 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
1) Check for local shop first because shipping now is a killer.
2) St. Louis Spring — They usually have the original prints/plans on file. Order additional arch if desired.
Re: Where to purchase leaf springs? [Re: 64Post] #1701405
11/21/14 09:50 PM
11/21/14 09:50 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run SuperStock springs on my 63 and I bought them from Mancini and got a good deal on them. Tell them you are a Moparts member and they should give you a 10% discount as they did for me. This is how it sits with the SS springs. Ron
Re: Where to purchase leaf springs? [Re: 383man] #1701406
11/23/14 02:01 PM
11/23/14 02:01 PM
Dixie Offline OP
Dixie  Offline OP
Good stuff guys, thanks. The reason I think it needs new springs is they were sagging pretty bad when I got it. I put helpers on it, and it did help for awhile. I've noticed while driving it recently, that when it hits a bump with more than one person in it, the rear tires scrape. It has new shocks, so I'm thinking the springs are giving a too little much bounce in the rear. $250/pr for a set of springs aren't in his budget. So, it'll just have to scrape for awhile.
I will check with a local shop on re-arching them. That might be the way to go. Finding a set in a junkyard these days maybe be hard to do, but that's a thought too.
Attached is a pic of it at a cruise-in this past summer. I think it has a pretty good stance. It was originally a slant 6 car, so the helpers did raise it a bit in the rear.
Re: Where to purchase leaf springs? [Re: Dixie] #1701407
11/23/14 04:02 PM
11/23/14 04:02 PM
NY
clemul Offline
clemul  Offline
NY
In my opinion Eaton springs is the only way to go. OEM supplier working off original blueprints in USA using quality materials. Can do stock -/+ 1",2",3". If can't afford it now it is worth waiting until you can. I was very happy with the quality of their work.
Re: Where to purchase leaf springs? [Re: clemul] #1701408
11/23/14 04:21 PM
11/23/14 04:21 PM
Maryland USA
beatgoeson Offline
beatgoeson  Offline
Maryland USA
BTW Randy, tell your son he has a great looking ride there! Very nice he and you should be proud!
Now if I could just talk me son into a cool car like that.
Re: Where to purchase leaf springs? [Re: clemul] #1701409
11/23/14 06:34 PM
11/23/14 06:34 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
Eaton is great and honest and they work from OEM info. I vote for them as well.
Re: Where to purchase leaf springs? [Re: beatgoeson] #1701410
11/23/14 06:42 PM
11/23/14 06:42 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
That is a sweet looking car.
I remember these cars doing what you describe back in the 70's.
It's more about the over size tires than wore out springs.
That's why those hated long shackles and air shocks were used.
Don't go that route.
I don't think you are gonna find 10 to 20 dollar springs in any junk yard either.
I would add a leaf and, or get yours redone. Talk to local hot rodders to find a good shop.
Maybe a slightly narrower or shorter tire might help, but it won't look as good...
I have mechanical Aptitude.
I can screw up anything.
Re: Where to purchase leaf springs? [Re: bboogieart] #1701411
11/23/14 10:21 PM
11/23/14 10:21 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Dixie thats one nice Demon your son has. Reminds me of my sons Dart pitured here which has the 002 & 003 SS springs on it. I like the Demons alot and your sons looks great. Ron
