Small Block Roller Lifters #1701229
11/20/14 07:51 PM
11/20/14 07:51 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Will the comp 828 come out without taking off the heads?
Indy heads
Re: Small Block Roller Lifters [Re: Scamp408] #1701230
11/20/14 10:29 PM
11/20/14 10:29 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
I don't know but I have a brand new set if you need...$375 plus shipping
Re: Small Block Roller Lifters [Re: Scamp408] #1701231
11/20/14 11:55 PM
11/20/14 11:55 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
With my W-9 motor I used to change out roller lifters all the time by fishing them up through the cylinder head with a telescoping magnet and a stiff piece of wire and a flashlight. In this case all you have to do is remove the valve cover rockers and pushrods. That motor used to eat lifters.
Just sayin.
SRT DEMON ONE SEAT
Re: Small Block Roller Lifters [Re: Scamp408] #1701232
11/21/14 02:21 AM
11/21/14 02:21 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Indy heads
I have edelbrock heads and my 828s won't come out with the heads on.
68 Barracuda Formula S 340
Re: Small Block Roller Lifters [Re: Bad340fish] #1701233
11/21/14 08:43 AM
11/21/14 08:43 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
The w9 give you more room than the std layout. If the eddies wont let you pull em prob the same with the Indy.
Re: Small Block Roller Lifters [Re: Bad340fish] #1701234
11/21/14 10:14 AM
11/21/14 10:14 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Indy heads
Same here, Eddy heads, comp roller lifters, close but no cigar with the heads on.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Small Block Roller Lifters [Re: FlyFish] #1701235
11/21/14 11:15 AM
11/21/14 11:15 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
If you look the deck surface is diff between the 2
Re: Small Block Roller Lifters [Re: Scamp408] #1701236
11/21/14 11:16 AM
11/21/14 11:16 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Eddie
Re: Small Block Roller Lifters [Re: Ron Silva] #1701237
11/21/14 07:11 PM
11/21/14 07:11 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Just sayin.
Hey Hey Hey!!!!!!!!!!! Your Back! !!!!!!!!
About time.
Matt
Re: Small Block Roller Lifters [Re: MattW] #1701238
11/23/14 11:04 AM
11/23/14 11:04 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I cant be the only one that encountered this.
Re: Small Block Roller Lifters [Re: Scamp408] #1701239
11/23/14 11:16 AM
11/23/14 11:16 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
My W9 59 Deg R3 Johnson Hydro lifters needs the head to come off. And I had the lifter gallery machined for the standard style lifters. Matt
Re: Small Block Roller Lifters [Re: MattW] #1701240
11/23/14 03:50 PM
11/23/14 03:50 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
318 Rollerblock OEM lifters, Commando aluheads = heads off to get lifters out Guess I have to live with the one ticking lifter....
Re: Small Block Roller Lifters [Re: Scamp408] #1701241
11/23/14 10:40 PM
11/23/14 10:40 PM
Indiana
maxie Offline
maxie  Offline
Indiana
I have mostly built and ran big block molars, but leaning toward building a 340. Has there always been different issues with roller lifters and small blocks? Why do you have to pull the heads to take out the lifters? Wont they come out if you remove the intake?
Re: Small Block Roller Lifters [Re: maxie] #1701242
11/24/14 03:25 PM
11/24/14 03:25 PM
Norway (old world)
Norway (old world)
No, they are too long and hit the heads when tried to pull out. I am not used to have such problems on a Mopar, maybe they got some ex-Ford engineers designing this....
Re: Small Block Roller Lifters [Re: Oyvind Mopar] #1701243
11/25/14 04:00 PM
11/25/14 04:00 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
The 59 degree angle (carried over from the poly days)certainly doesn't help as the angle makes it worse for removal. Although the 9.58" deck is taller than SBC and SBF but it doesn't seem to help at all.
WIZE
In Car:
Re: Small Block Roller Lifters [Re: Streetwize] #1701244
11/25/14 05:23 PM
11/25/14 05:23 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
I believe the high camlocation is the biggest isue
Re: Small Block Roller Lifters [Re: 1Fast340] #1701245
11/25/14 09:54 PM
11/25/14 09:54 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
exactly but the high cam location is why it is so easy to stuff so much stroke in them.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Small Block Roller Lifters [Re: dusturbd340W5] #1701246
11/25/14 11:12 PM
11/25/14 11:12 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I can take out my Crane ultra pro's with the heads on my 408, its tight and i have to wiggle them around but they will go.
