Re: 5.9 Cummins flywheel question
[Re: toomanymopars]
#1701131
11/20/14 01:50 PM
11/20/14 01:50 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Looking on Rockauto, for the Sachs flywheel which is the only one with specs, it appears the 07 is a dual mass the other not. Dunno about balance issues though.
[Re: Supercuda]
#1701132
11/20/14 02:46 PM
11/20/14 02:46 PM
Posts: 1,285 okla.
sam64
okla.
and if you replace a dual mass flywheel with a solid flywheel be prepared for a lot of noise.
[Re: toomanymopars]
#1701136
11/21/14 04:03 PM
11/21/14 04:03 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Like I said you are going to have to change the block adapter too. They are different thicknesses and the starters set at different depths.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
