Re: What is this thing on the Coil
[Re: Adam71Charger]
#1700973
11/19/14 10:49 PM
11/19/14 10:49 PM
RapidRobert
& it goes on the positive pri terminal which yours does
[Re: Adam71Charger]
#1700974
11/20/14 12:23 AM
11/20/14 12:23 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Can it cause ignition problems if it goes bad? Are certain coils designed to work with them, or is it just an add on?
Yes it can go bad. In general they get 'leaky" which means they loose capacitance. Which shows up as additional ignition noise in the radio. It does not interfere with ignition operation. BTW, condenser and capacitor are two terms for the same device. Condensor is an archaic term and is used by the automotive industry and 90 year old amateur radio operators. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: feets]
#1700977
11/20/14 12:41 AM
11/20/14 12:41 AM
Posts: 21,827 Kirkland, Washington
Pacnorthcuda
It is a radio noise suppression condenser...
Do they make one for the spousal unit?
Yes they do, but the most effective one has to be granted by a judge and its very expensive.
Many just put up with the noise.
[Re: Pacnorthcuda]
#1700978
11/20/14 01:38 AM
11/20/14 01:38 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Pitiful...
My 43 year-old OEM AM/FM is 'noise-free'...
There are ways...
