Re: Tell Me About my W9s [Re: Blucuda413] #1700735
11/28/14 02:14 PM
11/28/14 02:14 PM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
Re: Tell Me About my W9s [Re: Blucuda413] #1700736
11/28/14 04:41 PM
11/28/14 04:41 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I am a little curious why they have been sitting for as long as they have.
They are 48 degree , looks like beryllium copper seats , definitely drilled for port injection........98.73459 % likely they came from a sprint car.
Maybe a road racer.
It looks like there was a coolant passage drilled between the exhaust valves of the center cylinders....I have seen this in book form only ( How to build Big Inch Small Block MoPars ) but it is a nice choice for any motor that will see a lot of heat I bet.
I'd pressure test them and if everything is cool , then you probably have a nice set of heads.
Did they come with valves ?
Re: Tell Me About my W9s [Re: tubtar] #1700737
11/28/14 08:27 PM
11/28/14 08:27 PM
dogdays Offline
dogdays  Offline
This is just flat wrong! Showing those pictures right before a weekend, when I'll have nothing to do but sit and think about'em.
It's the worse kind of pornography.
R.
Re: Tell Me About my W9s [Re: dogdays] #1700738
11/28/14 09:48 PM
11/28/14 09:48 PM
Cairns Queensland Australia. T...
V
vc360 Offline
vc360  Offline
V
They look like RP version to me?
Re: Tell Me About my W9s [Re: vc360] #1700739
11/29/14 12:32 AM
11/29/14 12:32 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes look like a rp which would be a 48* head. Also have a 13* valve angle.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Tell Me About my W9s [Re: 1967dartgt] #1700740
11/29/14 02:17 AM
11/29/14 02:17 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Looks like a non raised port to me.
One way to check is all the Raised port W9's I've see take a -10 O-ring fitting for the water ports and the non raised were -8 O-ring
Re: Tell Me About my W9s [Re: SB412DUSTER] #1700741
11/29/14 07:52 AM
11/29/14 07:52 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Looks non rp to me too.
Re: Tell Me About my W9s [Re: Hot 340] #1700742
11/29/14 01:45 PM
11/29/14 01:45 PM
Alexandria, LA
Alexandria, LA
What you see is what I have, no valves. I have a set of 2.18 tit valves but the stem is smaller than 11/32. It's interesting about the RP vs non RP discussion, I don't know how to tell them apart. I do believe the water outlets are -10 size/threads, I'll verify next time I'm at the shop. Is there any other way to tell them apart?? How far is the port off the deck in each type head??
Re: Tell Me About my W9s [Re: Blucuda413] #1700743
11/29/14 02:04 PM
11/29/14 02:04 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
This pic is on Shady Dell's site
And this is what it says
"W9 RP (RAISED PORT) on left, "regular" W9 on right. W9 RP heads have .800" Raised intake ports. W9 RP hand port development, in house at Shady Dell will occur winter 2004/2005. Stay tuned...."
Re: Tell Me About my W9s [Re: SB412DUSTER] #1700744
11/30/14 10:32 PM
11/30/14 10:32 PM
Alexandria, LA
Alexandria, LA
I checked today and the heads I have do have -8 size water ports.
