heat riser spring #1699408
11/15/14 08:27 PM
11/15/14 08:27 PM
r.i.
stuman Offline OP
stuman  Offline OP
r.i.
Does any one know where to get just an exhaust manifold heat riser spring for a 69 hemi. You can get it in a repair kit, to the tune of around $400.00. Ouch. Spring just rotted away, everything else works fine.
Re: heat riser spring [Re: stuman] #1699409
11/16/14 01:02 AM
11/16/14 01:02 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Are other big block mopars the same as the hemi? I`m pretty sure I still have this NOS one.
Re: heat riser spring [Re: mopars4ever] #1699410
11/18/14 12:12 AM
11/18/14 12:12 AM
r.i.
stuman Offline OP
stuman  Offline OP
r.i.
not sure on the fit, but spring looks similar to the one in the book, not the best pic, What r u looking to get for it? thanks
Re: heat riser spring [Re: stuman] #1699411
11/18/14 05:38 AM
11/18/14 05:38 AM
md
mopars4ever Offline
mopars4ever  Offline
md
i tried to do some research and it appears that the hemi spring is a different part number so i would say the one i have won`t work for you. sorry
