'74 W200 Powerwagon, Door Channel & Brush Seals? #1699355
11/15/14 03:53 PM
11/15/14 03:53 PM
Rancho Cucamonga, CA
D_C Offline OP
D_C  Offline OP
New (to me) 1974 Dodge W200 Truck. The rubber window channels and inner/outer door window seals are in very poor, disintegrated/missing condition.
Looking for tips or advice on how to go about finding good replacement materials, affordable alternatives and installation advice.
Re: '74 W200 Powerwagon, Door Channel & Brush Seals? [Re: D_C] #1699356
11/15/14 07:37 PM
11/15/14 07:37 PM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
I bought an entire weatherstrip kit from summit for my 75. Worked pretty good, and reasonably priced.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: '74 W200 Powerwagon, Door Channel & Brush Seals? [Re: GTSDart340] #1699357
11/16/14 12:33 AM
11/16/14 12:33 AM
D_C Offline OP
D_C  Offline OP
Thanks. Did the kit include Window seals, or was it door gap weatherstripping only? What I need is the squeegee-like seal at the bottom edge of the window and the brush seal on the inside, plus the channel seals that frame the inner perimeter of the door window frame.
Re: '74 W200 Powerwagon, Door Channel & Brush Seals? [Re: D_C] #1699358
11/16/14 12:39 AM
11/16/14 12:39 AM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
It was a complete kit. Door seals, window seals, and the window fuzzies. The only thing it didn't have was the vent window seal.
Re: '74 W200 Powerwagon, Door Channel & Brush Seals? [Re: GTSDart340] #1699359
11/16/14 02:50 PM
11/16/14 02:50 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Got mine off ebay, for the '85. Keep in mind the wipers (fuzzies) are different for the pre '81s, they are straight where the 81 up have a curve at the rear.
The kit I got was IIRC about $130, and was as above, everything but the vent window rubber, and was a Precision brand.
Everything functioned as it was supposed to, the fuzzies leave a little to be desired, and the door opening weatherstrip is a push-on over the pinch weld rather than glue in place, like my original was, and yours will be.
I prefer the push on style, but it is a little thicker from the pinch weld out and made my doors harder to close, but others report no problems.
I tried some I got from the junkyard, also push on, and had the same result, time hasn't changed that, so I think it is the extra thickness.
I've just gotten used to it, slamming the door hard.
long/short of it, Precision kit works, I don't know if anyone else makes the kit, but what I have is better than what I had.
It takes gasoline to interest me.
Re: '74 W200 Powerwagon, Door Channel & Brush Seals? [Re: VL21] #1699360
11/17/14 03:38 AM
11/17/14 03:38 AM
D_C Offline OP
D_C  Offline OP
Thank You for the replies. Good to know.
Re: '74 W200 Powerwagon, Door Channel & Brush Seals? [Re: D_C] #1699361
11/17/14 03:50 AM
11/17/14 03:50 AM
woodcrest, CA
magnum440d100 Offline
woodcrest, CA
Restoration specialties has them Linky
Steele rubber might(?)
Re: '74 W200 Powerwagon, Door Channel & Brush Seals? [Re: magnum440d100] #1699362
11/18/14 06:24 PM
11/18/14 06:24 PM
D_C Offline OP
D_C  Offline OP
Thanks Kevin. Making some progress on the W200. Sunday, I mounted the front bumper brackets, new door hinge (from you), mounted new Used front left tire, cut the crumpled rear step-bumper/receiver hitch off the frame.
Someone had welded the bumper brackets to the frame and fabricated a really ugly receiver hitch.
Sunday evening, I finally mounted the Tail Gate. Couldn't mount it until I removed that bent up rear bumper. Seems to fit fine.
