Stainless trim on window channel #1698250
11/13/14 05:04 AM
11/13/14 05:04 AM
Texas
J.Armistead Offline OP
Texas
Anyone have a trick for getting the piece of Stainless trim off the door window channel? It appears to be spot welded in two places inside where the wing seal goes. Drilled them out but it still doesn't budge. Thought I'd ask before I screw it up. Thanks ahead of time.
J.
Re: Stainless trim on window channel [Re: J.Armistead] #1698251
11/14/14 10:42 AM
11/14/14 10:42 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Remove all screws especially the one at the top that is hidden behind the seal.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Stainless trim on window channel [Re: MOPARMIKE69] #1698252
11/14/14 10:43 AM
11/14/14 10:43 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Drill out the pegs
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Stainless trim on window channel [Re: MOPARMIKE69] #1698253
11/14/14 10:44 AM
11/14/14 10:44 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Wiggle up and down and pry easily with a screw driver if needed, and it will come out.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Stainless trim on window channel [Re: MOPARMIKE69] #1698254
11/16/14 02:00 AM
11/16/14 02:00 AM
Texas
Texas
Thanks Mike, I got that far..My dremel worked even better than the drill. I got the chrome part off, but it's that piece of stainless that comes up on the back side of the wing that I'm trying to get off the front channel now. I'd leave it on and have it polished but it has a small ding that needs taken out. There's 2 spot welds holding it to the channel that I drilled out, but it still doesn't want to give up.
J.
