MSD 6al wiring? #1698061
11/12/14 07:22 PM
11/12/14 07:22 PM
junction city oregon
V
viperblue72 Offline OP
V
Hooking up a msd 6al to my slant 6 to get rid of the lean burn system. Which wires in the Chrysler electronic distributor are + and -
Re: MSD 6al wiring? [Re: viperblue72] #1698062
11/12/14 07:54 PM
11/12/14 07:54 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Are you changing the distributor? The leanburn one has no advance mechanism in it.
MSD wiring diagram.
Kevin
Re: MSD 6al wiring? [Re: Twostick] #1698063
11/12/14 08:10 PM
11/12/14 08:10 PM
V
V
I did change the distributor to a pre-lean burn. It is a Chrysler distributor so the wires are black and white. Both go to a reluctor so I don't know which is which.
Re: MSD 6al wiring? [Re: viperblue72] #1698064
11/12/14 08:27 PM
11/12/14 08:27 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Chad,
Just a guess, Black would be negative.
Hook it up one way and put a timing light on it. Flip the wires, go with the wiring that is more advanced and time it from there.
IIRC, when wires are transposed for normal, timing is retarded with the mopar electronic stuff. MSD used to have the wiring transposed. Always made for some fun when swapping.
Re: MSD 6al wiring? [Re: RobX4406] #1698065
11/13/14 05:38 AM
11/13/14 05:38 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The pickup reads the front edge and rear edge of the reluctor. Wired properly it reads the front edge, wired backward it reads the rear. As stated before, it will change the timing. On my Slant the change was almost 30°.
Make sure the small red wire has voltage in key on and start. Some of the junctions you can lose voltage when in start postion. Guess how I know that?
