Mopar Stage 6 intake Questions #1697884
11/12/14 01:16 AM
11/12/14 01:16 AM
Colorado
funnycar65 Offline OP
Colorado
Is there an intake that will fit on the Mopar Performance stage 6 heads that will work on a RB block without the spacers?
Re: Mopar Stage 6 intake Questions [Re: funnycar65] #1697885
11/12/14 01:29 AM
11/12/14 01:29 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
yes there is.... the 4500 series one which I ran, and I'm pretty sure there was a 4150 version.
Re: Mopar Stage 6 intake Questions [Re: J_BODY] #1697886
11/12/14 01:48 AM
11/12/14 01:48 AM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
I have the 4150 version, can give part number and picture tomorrow.
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: Mopar Stage 6 intake Questions [Re: 23T Hemmee] #1697887
11/12/14 11:33 AM
11/12/14 11:33 AM
Colorado
Colorado
Thanks guys I see the 4500 series is still available
Re: Mopar Stage 6 intake Questions [Re: funnycar65] #1697888
11/12/14 11:59 AM
11/12/14 11:59 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
They offered the Stage VI RB intake in both standard and MW port options. The 4150 version wasn't a very good design out of the box and the one I tried required a LOT of plenum reworking by an intake specialist to make it usable. If you're looking into the 4500 version, you're better off.
Re: Mopar Stage 6 intake Questions [Re: BradH] #1697889
11/12/14 02:00 PM
11/12/14 02:00 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I've seen them on here from time to time for decent prices, I'm going to grab the next one I see.
Coming soon!!!!
Re: Mopar Stage 6 intake Questions [Re: funnycar65] #1697890
11/12/14 10:46 PM
11/12/14 10:46 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
results may vary..... I always had a pretty decent 60 ft time 1.36-1.39, respectable 1/8th numbers, but while I'd cover many cars in the 1/8th, they would drive around me on the top end. Even swapped from my 4.10 to a 4.56 gear with very little change. Finally bought the 4500 intake and an Ebay Carb Shop 1050 and slapped it on...... BAM! four tenths and 4-5 mph gain in the 1/4. My trap rpm went from 6400 to 7200.... put the 4.10 gear back in and went even quicker....mainly did it to get the rpm back down to a more "happy" level. The 4150 M1/spacer and holley 850 4150 carb were a definate cork in my system. This was a 4.15 stroke, 13-1, ultradyne NF69 mech cam, stage VI heads not max wedge ported by Dwayne Porter (info on them in the archives). Mild combo that was very easy on parts.
Re: Mopar Stage 6 intake Questions [Re: funnycar65] #1697891
11/13/14 12:29 AM
11/13/14 12:29 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Click on the attached chart.......then go all the way down to the 3rd from last (P4876127). I found one 2nd hand, but never bolted on a motor, by doing a google search. It showed up on Craigslist.
The intake ports are pretty small as cast, so you'll have to open them up to your cyl. head size.
https://www.monicattichrysler.com/comersus/store/inetsolution_chartView.asp?r=19
Here is possible source.....
https://www.monicattichrysler.com/comers...?idCategory=167
Re: Mopar Stage 6 intake Questions [Re: funnycar65] #1697892
11/13/14 11:06 PM
11/13/14 11:06 PM
Holly/MI
Holly/MI
Here's one if you're into a 4150 with Max Wedgie ports..........
http://www.ebay.com/itm/MOPAR-PERFORMANC...ed2&vxp=mtr
Re: Mopar Stage 6 intake Questions [Re: Dean_Kuzluzski] #1697893
11/15/14 02:21 PM
11/15/14 02:21 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I run the 4150 with a adapter and a 1050 4500 carb. The intake has been ported but it was this way when I bought it. I wonder if I went to the 4500 intake if my car would pick up at all.
67' charger 499 RB 10.57 at 127
