Re: Bolt on Fiberglass trunk lids? [Re: hustlin hoosier] #1697788
11/13/14 01:45 AM
11/13/14 01:45 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What kinda weight difference are people seeing with the bolt on one?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Bolt on Fiberglass trunk lids? [Re: bdaz smblk] #1697789
11/13/14 02:24 PM
11/13/14 02:24 PM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
aar makes a glass bolt on trunk lid.I don't know how much of a savings it is but I have one and it is very nice
I have an AAR as well. Can hardly tell the difference from steel.
Only issue was the lock did not fit. I had to grind the lock wider for the clip to slide in keep it in place. (fiberglass was thicker than steel) I removed the springs to keep from cracking it. I am not sure of the what I saved in weight, but I saved a ton in money, plus my steel trunk lid does not weight 30lbs. (I am guessing)
Re: Bolt on Fiberglass trunk lids? [Re: 1967dartgt] #1697790
11/13/14 10:04 PM
11/13/14 10:04 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
A stock 70 dart trunk lid is supposed to weigh 45lbs, and the glass one I am looking at from Unlimited is 15lbs, so a solid 30lbs if those numbers don't include hinges. I think thats pretty good
