Re: SixPack Metering Plates
[Re: lewtot184]
#1697585
11/11/14 08:21 PM
11/11/14 08:21 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
i did this once decade ago. you can use a '69 plate on a 70-71 carb but can't use a 70-71 plate on a 69 carb. the 69, or at least the ones i played with, had an additional passage that the 69 plate covered. slept some since then,... .
But you stayed awake long enough to get it right! ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: 62maxwgn]
#1697586
11/11/14 08:28 PM
11/11/14 08:28 PM
Posts: 3,916 usa
lewtot184
usa
figured it out the hard way,.. .
