6.76 Rod options? better than Eagle/Scat. (not anymore
#1697102
11/10/14 06:32 PM
11/10/14 06:32 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I'd like to find a better rod than Eagle/Scat but it seems that no one is making them anymore so I wanted to see if you guys knew of any other options.
If I didn't already have the 4.15 Callies crank and Diamond pistons I'd look to change stroke or move to longer rod (Hemi) and change the pin height on a piston, but it't too late for that.
I may have no choice but to go Aluminum if I want something better than Eagle/Scat. I understand Scat is making a pretty good rod for up to 1,000hp and this motor will make less than that but it's going in my KB block and I'd rather put a better rod in it if I can find one.
No availability for any of these manufactures 6.76 w/ .990 pin: Crower - $1,800 - no stock no plans Oliver - $1,300 - no stock no plans Lunati - $? - no stock no plans Carrillo - $? - no stock no plans Howards - $? - no stock no plans Manley - $? - no stock no plans
Help?
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: 6.76 Rod options? better than Eagle/Scat. (not anymore
[Re: WadeMetzinger]
#1697104
11/10/14 06:59 PM
11/10/14 06:59 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
You can still possibly offset grind the crank to 2.200 bearing, 4.270 stroke, use the common 6.7 long 2.200 bearing x .990 pin rods. Rod availability is now good, bearings are a touch cheaper, and you have fourteen more cubes. You could possibly go to 4.25 stroke and use custom gaskets to make up the .010 minus deck height, if you want a common combo.
[Re: Monte_Smith]
#1697111
11/11/14 02:14 AM
11/11/14 02:14 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Howards ? Their billet pieces look good on paper , but I have no first hand experience with them. Sorry. Read first....then type.
[Re: 72Swinger]
#1697113
11/11/14 12:59 PM
11/11/14 12:59 PM
BradH
Molnar DH6760YTB8-A
I mentioned Molnar above, but the OP said he doesn't consider them any better than SCAT.
[Re: JD Dart]
#1697114
11/11/14 01:10 PM
11/11/14 01:10 PM
Posts: 11,726 Portage,michigan
B3422W5
Portage,michigan
I have this set of rods why won't this work. http://www.callies.com/compstar/connecting-rods/h-beam/ CSE6760FS3D5AH
Yep....... Compstar makes great rods, ran a set in my 422 small block. Chuck@ best machine really likes them. 675 a set, Barton sells them and they are 990 pin Edit..... I am sure best carries them as well
[Re: BradH]
#1697115
11/11/14 01:12 PM
11/11/14 01:12 PM
Posts: 411 Big Island ,VA
JC Childress
Big Island ,VA
We have used tons and tons of Molnar rods and I can tell you, the finished product from Molnar far exceeds the quality of Scat rods. I know they both start out as Chinese rods but the quality is much better on the Molnar and we have several sets in pretty stout bracket engines ( over 1000hp ) and I know of several sets in higher hp turbo cars. I think you'd be happy with the rods from Tom Molnar.
J.C. Childress
(434) 665-9541
[Re: PETE@BESTMACHINE]
#1697118
11/11/14 07:28 PM
11/11/14 07:28 PM
WadeMetzinger
Tulsa, Ok
ok, sounds like I need to re-consider Compstar and Molnar rods.
I wished Callies would make an Ultra H-Beam for Mopar, I'm hearing Chevy builders are really impressed with them and hearing that some Oliver rod are having some issues which never used to happen.
I'm only going to make 850 or less HP so I know Eagle, Scat, Molnar and Compstars would do all I need just thought I'd look into a better rod for a little more insurance and be able to run them for 3,000 passes and not worry about them (since I'm putting them in my KB block), other than to change the bolt every now and then.
Thanks for the help guys!
[Re: WadeMetzinger]
#1697120
11/12/14 04:05 PM
11/12/14 04:05 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
If you really like that rod then I would do the math with the pistons you have and turn down the crank and adjust the stroke to use on of those rods, probably end up costing close to the same as a big dollar rod for a mopar journal ?
