Voltage regulator bracket? #169701
12/18/08 12:32 AM
12/18/08 12:32 AM
Kingsburg Calif.
Quikshft Offline OP
Quikshft  Offline OP
Kingsburg Calif.
Another item I might need?
Shot of a 70 Bee similar to mine, is that the bracket supporting the regulator to the firewall?
Re: Voltage regulator bracket? [Re: Quikshft] #169702
12/18/08 12:45 AM
12/18/08 12:45 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Yes......another 70 only thing!......just make sure you don't over paint stuff, you want it grounded!.....check with a meter later to confirm continuity
Re: Voltage regulator bracket? [Re: DAYCLONA] #169703
12/18/08 12:50 AM
12/18/08 12:50 AM
Kingsburg Calif.
Quikshft Offline OP
Quikshft  Offline OP
Kingsburg Calif.
OK very good. And thanks for the tip on grounding, wouldn't have thought of that.
Re: Voltage regulator bracket? [Re: Quikshft] #169704
12/18/08 02:37 AM
12/18/08 02:37 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The bracket should be plated Gold Cad IIRC
Re: Voltage regulator bracket? [Re: Quikshft] #169705
12/18/08 09:29 AM
12/18/08 09:29 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: Voltage regulator bracket? [Re: gtx6970] #169706
12/18/08 10:33 AM
12/18/08 10:33 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Replated original with correct bolts.
Re: Voltage regulator bracket? [Re: 62maxwgn] #169707
12/18/08 09:45 PM
12/18/08 09:45 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I added one to my 69 when I did the conversion
1MYTGTX
