Driveline angles?
#1696334
11/08/14 09:17 PM
11/08/14 09:17 PM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
Im building an AWB -65 Valiant. I want to mount the engine high! How do you set up the different angels? Front moved forward 4", rear moved forward 12" firewall mowed back parallel with the doors. Engine setbackaround 10"
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Driveline angels?
[Re: Crizila]
#1696341
11/10/14 12:52 AM
11/10/14 12:52 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Set the engine and trans in your desired location and angle,set the rear end and point the pinion to the trans output shaft using a string line.Install the driveshaft.Now adjust the pinion angle for your suspension type.Adjust the angle from pinion to trans output shaft or off the driveshaft angle to pinion either will work,For reference ie:springs-4 to 6 degrees negative,ladder bar-2 degrees negative and 4 link-1 degree negative.We preferr using the shaft to pinion angle.
Good, very understandable, clear explanation.
And if the driveline is aligned in this preferred manor, this is the Only time you can use the Driveshaft as a Reference point for a Driveline Pinion angle.
[Re: B G Racing]
#1696343
11/10/14 04:46 PM
11/10/14 04:46 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Its THIS SIMPLE. Point the tailshaft at the pinion, roll the pinion wherever it needs to be, pull a string, weld the mounts up.....DONE.
Monte
