Page 1 of 4 1 2 3 4
moly or mildsteel cage? #169612
12/17/08 10:49 PM
12/17/08 10:49 PM
St. Louis Mo. USA
P
Pleaz Offline OP
Pleaz  Offline OP
P
St. Louis Mo. USA
Im having my mild steel cage taken out and replaced with a moly one. Does a moly cage go brittle after 4, or 5 years? Where a mild steel cage can last up to 15 years? If this is the case, ill just save my money. The weight difference cant be that much anyway. Im not sure if i should stick with what i got, or replace it.
Re: moly or mildsteel cage? [Re: Pleaz] #169613
12/17/08 11:00 PM
12/17/08 11:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No, a moly chassis does NOT turn brittle in 4 or 5 years
that BS. The weight isnt all that much lighter but
it is lighter, I dont have the numbers in front of
me what the difference is in a foot. Its up to you
weather you replace it or not, they do cost more
because its all tig welded, but a moly chassis is
more rigid
Re: moly or mildsteel cage? [Re: MR_P_BODY] #169614
12/17/08 11:09 PM
12/17/08 11:09 PM
St. Louis Mo. USA
P
Pleaz Offline OP
Pleaz  Offline OP
P
St. Louis Mo. USA
Thanks. Im just wondering if the extra money, is worth a little weight.
Re: moly or mildsteel cage? [Re: Pleaz] #169615
12/17/08 11:12 PM
12/17/08 11:12 PM
Colorado,U.S.A
4404dart Offline
4404dart  Offline
Colorado,U.S.A
I'd do a moly cage. It will last forever, it's worth more if you sold the car. You can put the weight you save somewhere else, or just save the weight.
Re: moly or mildsteel cage? [Re: 4404dart] #169616
12/17/08 11:21 PM
12/17/08 11:21 PM
Cab_Burge Online work
Cab_Burge  Online Work
I also agree with MRPBODY, the moly cage is stronger, safer, lighter and better in a crash, especially on a drag car. That being said NASCAR wants mild steel, probally because a lot of the good old boys do a lot of the work themselves in the lower, slower local race cars and they don't want them trying to weld chrome moly with a OX Acetelene torch
Re: moly or mildsteel cage? [Re: Cab_Burge] #169617
12/17/08 11:27 PM
12/17/08 11:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I believe they use mild due to them busting up their
cars all the time and always replacing tubing and
they have a PILE more tubing in their cars plus
they have a pretty high minimum weight
Re: moly or mildsteel cage? [Re: MR_P_BODY] #169618
12/17/08 11:44 PM
12/17/08 11:44 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Has to do with the tube absorbing shock loads. Moly being more rigid, transfers more load to the driver than mild steel.
Re: moly or mildsteel cage? [Re: Pleaz] #169619
12/17/08 11:53 PM
12/17/08 11:53 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
I would rather wreck a car with a MS cage than moly any day. I sure wouldn't cut out a legal ms cage to replace, It is only lighter because it is thinner wall tubing.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: moly or mildsteel cage? [Re: Dan Brewer] #169620
12/18/08 12:01 AM
12/18/08 12:01 AM
St. Louis Mo. USA
P
Pleaz Offline OP
Pleaz  Offline OP
P
St. Louis Mo. USA
I have always heard that moly is twice as light, and twice as strong. That is why i wanted to make the change.
Re: moly or mildsteel cage? [Re: Pleaz] #169621
12/18/08 12:09 AM
12/18/08 12:09 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Not sure I agree with that statement..Here is a question you need to ask yourself. How fast do you plan to go with this car? If it is just a rollbar I dont see the added expense of it being Moly worth the hassle. I suggest you build whatever your budget will allow for the ET you are after. You may find after pricing it out that the money spent for a moly bar will be batter spent elsewhere. FWIW my car is a Mild Steel certed to 7.50...
Re: moly or mildsteel cage? [Re: Pleaz] #169622
12/18/08 12:10 AM
12/18/08 12:10 AM
Galesburg IL.
dillon383 Offline
dillon383  Offline
Galesburg IL.
Molly and Mild weigh the same, it's just the fact the molly is stronger so you can use a thinner wall tubing and get the same or more strength.
Re: moly or mildsteel cage? [Re: Pleaz] #169623
12/18/08 12:10 AM
12/18/08 12:10 AM
St.Louis ,Mo.
72sat Offline
72sat  Offline
St.Louis ,Mo.
the only reason I would go to moly,is for certification.If your car can make the weight,and cert. for the class you want to run;then why spend the extra money.
Re: moly or mildsteel cage? [Re: 72sat] #169624
12/18/08 12:14 AM
12/18/08 12:14 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well if it is only for certification then unless you plan on running faster than 7.50 mild steel is fine.
Re: moly or mildsteel cage? [Re: Al_Alguire] #169625
12/18/08 12:25 AM
12/18/08 12:25 AM
St. Louis Mo. USA
P
Pleaz Offline OP
Pleaz  Offline OP
P
St. Louis Mo. USA
My mild steel cage is only legal for 10.0. Im hoping to be in the 9s next year. So i thought i would just go with a new legal moly cage. I could just add on to what i have, but im sure the old part wouldnt pass. And i thought moly would just be safer. Thanks for the input guys.
Re: moly or mildsteel cage? [Re: Al_Alguire] #169626
12/18/08 12:26 AM
12/18/08 12:26 AM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
moly is more brittle, so wouldn' it be more prone to cracking or is that just a myth.
Re: moly or mildsteel cage? [Re: 604 Hemi GTX] #169627
12/18/08 12:51 AM
12/18/08 12:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Why is it more brittle Its stronger with less flex
Re: moly or mildsteel cage? [Re: MR_P_BODY] #169628
12/18/08 01:41 AM
12/18/08 01:41 AM
Boynton Beach, Fl
Rapid588 Offline
Rapid588  Offline
Boynton Beach, Fl
While it is true mild steel has a little 'give' to it, these top 2 examples of 10 second 'mild steel' cages gave way too much..... the top one was coming in on the driver and had already failed......
the second pic of a buddy of mines cage also was 'giving' and was a hairs breath away of crushing him when he got into a little (very little) antifreeze of another car that had just run.
It may be hard to see in these pics unless you can zoom in, but both these mild steel cages deflected WAY too much for safety.
This next moly caged car hit and went over the wall at Orlando and disentegrated, but the moly cage did not deflect at all and integrity of chassis was still 100% intact.
93 Dodge Stealth - Supercharged 526ci Hemi
93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS
67 Hemi GTX (may the 4speed with you!)
Re: moly or mildsteel cage? [Re: Rapid588] #169629
12/18/08 02:43 AM
12/18/08 02:43 AM
A picture is woorth a 1000 words, these three speak volume of why all the Pro cars use chrome moly tubing in there cars. Weight and speed have a lot to do on the total impact loads, I would rather be a in a car(and I am) with a chrome moly bar or cage than mild steel any day that I'm in a crash
Re: moly or mildsteel cage? [Re: Rapid588] #169630
12/18/08 08:10 AM
12/18/08 08:10 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Looking at that cage, a gusset to the windscreen bar and Door bar could have minimised that. It certainly does look worrying though. I can also see why certain builders use a straight bar from the door bar footing to where the windscreen bar joins the door bar.
AL....
Alan Jones
Re: moly or mildsteel cage? [Re: Pleaz] #169631
12/18/08 08:45 AM
12/18/08 08:45 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
Is this something new
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Page 1 of 4 1 2 3 4
