Re: Small block water pump question.
[Re: Lmopar69]
#1695794
11/07/14 05:15 PM
11/07/14 05:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I believe the Magnum water pump is shorter, but it's reverse rotation so you'd need the magnum timing cover, which is also shorter. Probably need to convert to the magnum pulleys too.
[Re: Lmopar69]
#1695795
11/07/14 06:02 PM
11/07/14 06:02 PM
RapidRobert
the pre 70 cast iron pump is significantly shorter but the nipple is on the DR side so if your rad nipple is on that same side there is barely enough room to see the marks if you aim the light just right or you can make a new tab for the pass side & there's a guy that has several of the 68 ish pass side bolt on timing tabs for $20 to your door and a new corresponding dampener slit. I believe MP has a race cast iron (thin) pump with the nipple on the pass side (like the later alum ones) but it is $$$ & you might not need the flow for a stock app but the nipple would be on the pass side & it is a thinner pump. You sure you cant solve your dilemma with the right pulley?
[Re: Lmopar69]
#1695797
11/08/14 01:24 AM
11/08/14 01:24 AM
Posts: 27,475 So Cal
autoxcuda
So Cal
The problem is firewall to radiator space.
Do you have one of those Champion radiators? They make the fan spacing real close.
What viscous clutch fan are you using? Have you tried the Jan Fan Clutch: Hayden 2765 ? It's about the shortest still available except for the 070 repops: https://board.moparts.org/ubbthreads/show...e=0#Post8316897
[Re: autoxcuda]
#1695798
11/08/14 01:45 PM
11/08/14 01:45 PM
RapidRobert
If the dimentions of the Hayden clutch fan setup mentioned dont do the trick then a different rad or a shorter pump. I called the dealer just now & the MP pump I mentioned is NS1 but likely one of the aftermarket pump mfrs has one (thin with pass nipple) then a shallower pulley to bring the belt groove back forward to align with the crank/alt pulleys. As you know you can move the alt back & forth a bit & Mancini has different thickness spacers for the crank pulley to come forward & a hardcore option would be to machine the dampener face to move the pulley rearward. Holler how it turns out & post the length of the Hayden if you find that info
