Page 3 of 4 1 2 3 4
Re: How Fast before Frame Connectors are needed ? [Re: domingo] #1695750
11/30/14 08:33 AM
11/30/14 08:33 AM
gregsdart Offline
gregsdart  Offline
Another thought on when they are needed. Look at the math for a basically modified street car on stickys that hooks, even running 14.0s.
3.91 gears, 3,000 stall converter, mild 440 ,450 ft lbs torque at stall speed, no spin.
Torque x converter torque multiplication, times trans ratio times rear gear for the torque at the hit.
450 x 2 = 900 x 2.45 first ratio =2205 ft lbs x 3.91 rear gear = 8621 ft lbs of torque working to hurt your chassis! Now take the spring front segment length to figure force on the spring hangers.
8621 divided by 20 inch times 12 inch = 5173 ft lbs load, divided by two hangers, or 2586 lbs of force on each hanger.
It may only last the first two feet, but that is where max torque to the tires will be.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: How Fast before Frame Connectors are needed ? [Re: cdoublejj] #1695751
11/30/14 09:36 AM
11/30/14 09:36 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
They can be installed in a variety of ways as not to cut,weld or modify the floor pan.
Re: How Fast before Frame Connectors are needed ? [Re: ProSport] #1695752
11/30/14 01:12 PM
11/30/14 01:12 PM
france
jose jones Offline
jose jones  Offline
france
After reading this thread I'm starting to realize my Mopar Performance bolt-in frame connectors are useless.
Would they be ok if I have a friend weld them in, or do they really need to come up through the floor?
The Mopar Performance frame connectors work just fine, throw away the bolts and weld them in place they will stiffen the frame
Re: How Fast before Frame Connectors are needed ? [Re: Monte_Smith] #1695753
11/30/14 09:53 PM
11/30/14 09:53 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Ok sounds good, I will get them welded on each end.
I've been saying all along that this particular car will not have a cage in it but I'm starting to think a 6 point bar might from turning into a pretzel as the motor will be easily capable of running 10's if I ever take it to a track. But the rear seat needs to be accessible.....decisions decisions.
On a street car, to have rear seat access with a roll bar, at least from the pass side, run a diagonal bar from high on the pass side to low on the driver side, then install a bar behind the drivers seat from main hoop to diagonal bar. This supports the hoop side to side, gives a seat bar and a place to mount harness and also leaves a large opening on pass side to get in back seat..........just watch your head......LOL!!! I have also gone from the middle of hoop straight down to top of trans tunnel and then added seat bar behind driver. This leaves the whole pass side area open to get in back
Monte
These are great ideas for street guys, Monte. I recently saw a bar in a chevelle that had the standard cross-bar behind the seats, but had a swing out section in it. was hinged mid-span, and swung forward, locking out a few inches inside the main hoop on the passenger side. I asked the guy if it passes NHRA, and he said "probobly not, but I've had never had it questioned at tech before".
Re: How Fast before Frame Connectors are needed ? [Re: B G Racing] #1695754
12/01/14 01:27 AM
12/01/14 01:27 AM
USA MO
cdoublejj Offline
cdoublejj  Offline
USA MO
So qualms/issues with US Car Tool product then? So far I have been reading good things about them.
Re: How Fast before Frame Connectors are needed ? [Re: cdoublejj] #1695755
12/01/14 01:53 AM
12/01/14 01:53 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I am a firm believer that the frame ties need to go through or at least attach to the floor. I have the old weld in/bolt in MP (Comp Eng?) unit in my 4-speed car and they bend up and touch the floor when put the car up and the jack stands are under the frame instead of the control arms. It didn't do that when it had an eight point roll bar. If I was going to leave it without the roll bar I'd have to weld them through the floor to be comfortable. The car launches hard enough to bend leaf spring segments and I already had to repair the a-pillar to cowl joint once which entailed repainting the car. That was a ton of work that could have been avoided if my brain was functioning correctly when purchasing the connectors years ago. IMO any car that gets beat on should have them.
Re: How Fast before Frame Connectors are needed ? [Re: ] #1695756
12/01/14 02:37 AM
12/01/14 02:37 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Raced my Cuda regularly back in the early 80's. Wasnt real fast ran 12.80's. Drove it to the track and back. I majorly twisted the car running even that slow. Buckled one 1/4, up into the roof. I'm w/everyone else here. Put them on. It will save the car.
Ok
Re: How Fast before Frame Connectors are needed ? [Re: cudatom] #1695757
12/01/14 02:25 PM
12/01/14 02:25 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We would never cut the floorpan,but would rather weld a good stiff rail 2X2 or 2X3 minimually 1/8 thick from the trans crossmember area to heavy frame section at the rear.We add a 3"X6" flange to the rail at the front and weld it to the crossmember for eliminating any point load or twist that can tear the stock metal.You can further weld the driveshaft loop and rear suspension(ladder bar and etc) cross member to these rails to further stiffen the chassis,gussets can also be added at critical areas.If your going to start wacking and welding on the floor pans we suggest unloading the sprung weight and jigging the chassis on a frame machine.
Re: How Fast before Frame Connectors are needed ? [Re: B G Racing] #1695758
12/01/14 03:05 PM
12/01/14 03:05 PM
California
mickm Offline
mickm  Offline
California
i have the US ones. i've heard that some fit really well, and are almost a straight weld in job, but mine were quite off. i did a bit of grinding on them before i turned them over to the guy who installed them, and he did a LOT more. but they are in, and look fantastic, and make a big difference! i like these best as yes, most likely the factory would have done something like this had they done it.
Re: How Fast before Frame Connectors are needed ? [Re: mickm] #1695759
12/02/14 02:29 AM
12/02/14 02:29 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Does anyone have any pics of the US frame connectors mounted in there cars?
Re: How Fast before Frame Connectors are needed ? [Re: racerx] #1695760
12/03/14 12:55 AM
12/03/14 12:55 AM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
I went 2x3. They feather IN to the car under the front seat and protrude about 1.5-inch in the rear seat floor area.
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: How Fast before Frame Connectors are needed ? [Re: racerx] #1695761
12/04/14 01:50 AM
12/04/14 01:50 AM
USA MO
cdoublejj Offline
cdoublejj  Offline
USA MO
http://www.ebay.com/itm/MOPAR-Weld-in-Fr...555&vxp=mtr
they sell an entire chassis stiffening kit,
http://www.ebay.com/itm/US-Car-Tool-Mopa...acf&vxp=mtr
you can get them on the eBay and the official USCarTool website.
Re: How Fast before Frame Connectors are needed ? [Re: cdoublejj] #1695762
12/04/14 12:05 PM
12/04/14 12:05 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Missed Hotchkis' 25% off sale or I would have bought them from there.
Re: How Fast before Frame Connectors are needed ? [Re: 68KillerBee] #1695763
12/04/14 01:39 PM
12/04/14 01:39 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Making provisions for pass. to get in back seat? Yea right, the picture that comes to mind is going to hospital for the pass. concussions they get banging around inside those bars. Me and one front pass. is all it will be, if my buddys want to ride around we'll use the Mercedes.
Put the frame connectors in, who really cares what the floor looks like.
Re: How Fast before Frame Connectors are needed ? [Re: cdoublejj] #1695764
12/04/14 09:47 PM
12/04/14 09:47 PM
Mo.
racerx Offline
racerx  Offline
Mo.
those fit the floor boards pretty well, wish I new bout these when I purchase my DC ones.
Re: How Fast before Frame Connectors are needed ? [Re: cdoublejj] #1695765
12/05/14 03:54 AM
12/05/14 03:54 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Every semi serious (12 sec) street car should have connectors and all the support items you can add. I didn't see anyone mentioning the 8-10 inch fold that appears above the rear wheels in the middle of the quarter when you don't.
Leave the gun.......take the Cannoli's....Mike
Re: How Fast before Frame Connectors are needed ? [Re: mike s] #1695766
12/05/14 03:22 PM
12/05/14 03:22 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
My mid-12 second car must be an underachiever because after 80 or so runs on slicks with no subframe connectors and 1.68-1.70 60 foot times, I haven't seen any signs of tweaking or damage yet.
But I do want to add them to see if they will improve my 60 foot times or ETs. Anyone have any before and after data regarding that?
Do the F.A.S.T. cars run subframe connectors?
Re: How Fast before Frame Connectors are needed ? [Re: 67Satty] #1695767
12/05/14 04:30 PM
12/05/14 04:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I added those years ago before the 6-point bar and it definately made it more consistent in a high 11-low 12 sec. car..........
Re: How Fast before Frame Connectors are needed ? [Re: Thumperdart] #1695768
12/05/14 04:38 PM
12/05/14 04:38 PM
dogdays Offline
dogdays  Offline
In my opinion, one should add them if one intends to put the car on the road or track. Trailer queens, maybe not so much.
What I seem to remember from back in the day is movement at the welded/leaded line where the quarter panel joins the roof. In some cases the paint would actually flake off at the joint, and there'd be a noticeable bulge.
The cars weren't all that fast back then, and it seemed to be mostly bigblock cars.
R.
Re: How Fast before Frame Connectors are needed ? [Re: gregsdart] #1695769
12/05/14 05:55 PM
12/05/14 05:55 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Pretty safe bet that if you could measure the loads at the front spring hangers your numbers would be way off - the right side would be much higher than the left due to torque trying to rotate the housing and pick the right tire up.
And food for thought - if frame connectors are so effective, why didn't the factory use them instead of torque boxes that tie the sub-frames to the rocker boxes? You see a lot of factory installed (on all makes) torque boxes on high H/P cars and convertibles, but rarely (if ever) do you see factory installed sub-frame connectors. Personally I don't bother with sub-frame connectors unless I also tie the rockers in too.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Page 3 of 4 1 2 3 4
