71 B body guys with AMD inner wheel houses look closely #1694900
11/05/14 08:43 PM
11/05/14 08:43 PM
Willow Grove PA
71sat440 Offline OP
Happy Birthday 71sat440  Offline OP
Willow Grove PA
I got an inner right wheel house from AMD a couple months ago and just got the right side outer (Was out of stock most places for awhile)
When I went to fit the tubs together I saw a weird line on the inner tub..........
Looked closer, it couldn't be.............
Yup, daylight, where the line is crimped a couple inches from where the 2 halves meet, it was crimped so much it started to shear the metal.
At first it was a hairline of daylight about an inch long but I started poking it with my fingernail and it turned out the metal was cut clear through for 4 or five inches but the rest had filled with primer you couldn't tell at first.
So if you have the inner right, look real close, I'll probably just weld thing thing shut but I would hate for someone to paint their car only to have the primer crack and have a split in their wheelhouse later.
Re: 71 B body guys with AMD inner wheel houses look closely [Re: 71sat440] #1694901
11/05/14 08:49 PM
11/05/14 08:49 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
unless already welded in Id send it back...you just got a bad one...when stamped if it is lubed too much or not enough it can fracture easily.....
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: 71 B body guys with AMD inner wheel houses look closely [Re: 72N96RR] #1694902
11/05/14 09:27 PM
11/05/14 09:27 PM
Willow Grove PA
71sat440 Offline OP
Willow Grove PA
Considering I'll be welding on quarters, inner and out wheelhouses, and trunk extensions another 5 inch weld isn't gonna kill me.
Unless someone thinks theres another problem like metal might be too thin or something, its probably not worth the boxing, return shipping, back to me shipping etc.
Re: 71 B body guys with AMD inner wheel houses look closely [Re: 71sat440] #1694903
11/06/14 12:05 PM
11/06/14 12:05 PM
MarkMcDonald Offline
I used one last year without any problems. The fit was great and it was the right side also!
Re: 71 B body guys with AMD inner wheel houses look closely [Re: MarkMcDonald] #1694904
11/06/14 05:36 PM
11/06/14 05:36 PM
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
a new one wont be any thicker..it split when stamped...id send it back..unless the weld isn't seen or you grind it smooth
Re: 71 B body guys with AMD inner wheel houses look closely [Re: 72N96RR] #1694905
11/10/14 10:14 PM
11/10/14 10:14 PM
Up a holler, down a crick
booger Offline
booger  Offline
There's a fair chance the next one you get will be the same way. It's not like the things are each hand made.
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
Re: 71 B body guys with AMD inner wheel houses look closely [Re: booger] #1694906
11/11/14 10:01 AM
11/11/14 10:01 AM
maryland
74yellowduster Offline
maryland
on A bodies their wheel houses are "iffy"
on my '74 duster the quarters fit perfectly. the floor pan fit perfectly. inner fenders perfect.
AMD wheel houses needed major massaging to fit.
