Page 1 of 3 1 2 3
B-1 Originals rocker arm ratio #1694730
11/05/14 02:04 PM
11/05/14 02:04 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
I’m in uncharted territory (for me) here. Please be nice with regards to my ignorance.
Ok, when it comes to rocker arm ratios, who determines the ratio? I mean is it the rocker arm manufacturer that says “this ratio ### is the best for your head” or does the cam company, or is it the head manufacturer? I see different guys with B-1’s have all sorts of different ratios. Or is it the engine builder themselves that says what ratio to use?
I do know that some guys use the different ratios to change their cam specs a bit for fine tuning. But that’s it.
I’ve never had to deal with this situation before. I’ve just used what I had and told the cam manufacturer what ratio I was using.
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: B-1 Originals rocker arm ratio [Re: 1320Dart] #1694731
11/05/14 02:14 PM
11/05/14 02:14 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
!.7 here.
Re: B-1 Originals rocker arm ratio [Re: 1320Dart] #1694732
11/05/14 02:24 PM
11/05/14 02:24 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
IMO It's the manufacturers that come up with the best ratio for the design of the cyl. head. That said, several engine builders have their own ideas to find a tad more power, and it should be left to the smarter folks.
Re: B-1 Originals rocker arm ratio [Re: camastomcat] #1694733
11/05/14 02:27 PM
11/05/14 02:27 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
1.7's here.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: B-1 Originals rocker arm ratio [Re: 1320Dart] #1694734
11/05/14 02:30 PM
11/05/14 02:30 PM
Changing the rocker ratio affects the engine in two different ways, how far the valves open, how long they stay open and how fast the valves open I've seen arguments on here from folks that think the duration is not affected by the rocker ratio, evidently they have never charted a cam opening on the same engine with two different ratio rockers
Re: B-1 Originals rocker arm ratio [Re: Cab_Burge] #1694735
11/05/14 02:40 PM
11/05/14 02:40 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
It redesigns the cam in both lift and duration as well as power range and etc.
Re: B-1 Originals rocker arm ratio [Re: pittsburghracer] #1694736
11/05/14 02:40 PM
11/05/14 02:40 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
I've seen 1.6 to 1.83 for ratios on just the B-1's
What brand is preferred with the B-1's?
I planned on T&D paired rockers. But before I pulled the trigger I was wondering about the rocker ratio and had to ask.
Greg
Re: B-1 Originals rocker arm ratio [Re: 1320Dart] #1694737
11/05/14 02:47 PM
11/05/14 02:47 PM
dogdays Offline
dogdays  Offline
A lot depends on the camshaft, as well. I'd start there.
R.
Re: B-1 Originals rocker arm ratio [Re: Cab_Burge] #1694738
11/05/14 02:48 PM
11/05/14 02:48 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
So when you tell your cam manufacturer your rocker ratio, they grind the cam according to your ratio. And everything is golden correct?
Greg
Re: B-1 Originals rocker arm ratio [Re: dogdays] #1694739
11/05/14 02:50 PM
11/05/14 02:50 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
R.
Can you elaborate a little more please?
Greg
Re: B-1 Originals rocker arm ratio [Re: B G Racing] #1694740
11/05/14 02:55 PM
11/05/14 02:55 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
I'm having trouble following this, duration numbers are specified in regards to tappet lift at the lobe correct? Wouldn't changing rocker ratio only affect lift at the valve in regards to lobe lift? Sure it will affect the rate of lift at the valve just as a result of the changed ratio, I just don't see how the ratio change could physically change the the profile ground on the lobe which sets duration
Re: B-1 Originals rocker arm ratio [Re: GTS340] #1694741
11/05/14 03:05 PM
11/05/14 03:05 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
If it were me I would call your cam grinder and tell him what you are wanting to do, RPM, Power, ect...
I would tell the cam grinder what ratio you plan on running 1.7, 1.75 ect...
Call T&D and never look back. Best rockers out there in MHO.
Re: B-1 Originals rocker arm ratio [Re: Biginchmopar] #1694742
11/05/14 03:48 PM
11/05/14 03:48 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Camshafts are limited by the available blanks and the lobes those blanks have and actually how big a lobe can physically fit in the cam tunnel. So most consider a .500 lobe a big lobe, yet when coupled with a 1.5 rocker, that only gives .750 lift......that's pretty damn small. So say you want .900 lift and have a 1.5 rocker. That would require a .600 lobe. Ain't gonna happen, no such thing on a stock journal size blank. Now that same .500 lobe mentioned before, when put with a 1.8 rocker, gives you .900 lift.
Monte
Re: B-1 Originals rocker arm ratio [Re: Monte_Smith] #1694743
11/05/14 03:55 PM
11/05/14 03:55 PM
Idaho
1320Dart Offline OP
1320Dart  Offline OP
Idaho
Monte
Hi Monte-
Does that change much if a person was to run a 54mm cam? Or does that just help keep the core diameter bigger?
Greg
Re: B-1 Originals rocker arm ratio [Re: GTS340] #1694744
11/05/14 04:46 PM
11/05/14 04:46 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Draw the existing lobe as designed with the designated rocker ratio ie:1.5 ratio,then super impose the same lobe with 1.7 ratio rocker movement and follow the cycle from where the movement starts at the ramp to max lift as well as dwell time.It will travel well outside of the original cam demension.As Monte explained about cam core/lobe size your limited to certain dementions for clearence and geometry design.Big lobes sometimes will interfere with rods especially with large strokes and valve train geometry.This is why you see raised cams,spread bores and lifter cup height.The big journal cam cores are to strengthen the shaft and minimize flexing.Large lobes with steep ramps create problems keeping the lifter in contact and bouncing at high rpms which is why we have to use ultra heavy spring pressure and ultra expensive componants.
Re: B-1 Originals rocker arm ratio [Re: B G Racing] #1694745
11/05/14 05:11 PM
11/05/14 05:11 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Taking measurements from the same give point ie: .050 valve lift? Or as soon as indicator starts to move?
Re: B-1 Originals rocker arm ratio [Re: GTS340] #1694746
11/05/14 05:17 PM
11/05/14 05:17 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Measure it from any point after bottom base circle,.020,.050.
Re: B-1 Originals rocker arm ratio [Re: B G Racing] #1694747
11/05/14 05:33 PM
11/05/14 05:33 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
There will definitely be a change of valve rate of lift due to rocker ratio. The duration @ .050 on the cam hasn't changed, just the rate of lift at the valve and amount the valve is opened IE: .075 with 1.5 ratio and .085 with 1.7, is this really considered a change in duration? If so do you also consider it a duration change when you change roller lifters from one size roller wheel to another?
I was taught duration is at the lobe only
Re: B-1 Originals rocker arm ratio [Re: GTS340] #1694748
11/05/14 05:38 PM
11/05/14 05:38 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Both the rocker ratio (obviously) AND the roller lifter diameter can result in changes to the effective lift curve at the valve. The Crane Cams tech link below talks about how the duration measurement at the lobe changes due to wheel diameter changes:
http://www.cranecams.com/bulletins_listview.php?s_id=9
Re: B-1 Originals rocker arm ratio [Re: BradH] #1694749
11/05/14 06:47 PM
11/05/14 06:47 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Another tidbit...I believe that a B1 Original motor would require less pushrod clearancing with 7/16 pushrods if you used 1.8 rockers vs. say 1.7's.
Page 1 of 3 1 2 3
