68 Barracuda front vent window installation #1694103
11/04/14 01:40 AM
11/04/14 01:40 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
Putting a 68 Barracuda door back together (bought as a basket case). I am trying to install the vent window, and the lower guide rod will not slip all the way into the whole. I have the little pin lined up, but there must me some magical trick to get it all the way down. Any suggestions?
Dave in Colorado
Re: 68 Barracuda front vent window installation [Re: dssaa] #1694104
11/04/14 06:36 AM
11/04/14 06:36 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
This lower guide rod? The rod is pinned, and the pin goes in the slot of the clamp.
The Phillips screw on the clamp needs to be backed off for the clamp to clear the pin that's in the rod. If the vent frame is still in the door, you might need to remove the whole frame to loosen that clamp.
The 68 parts book shows an exploded view of the door interior parts in Chapter 23 here:
http://www.mymopar.com/index.php?pid=107
Re: 68 Barracuda front vent window installation [Re: kentj340] #1694105
11/04/14 06:42 AM
11/04/14 06:42 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Close up view of the pin.
Re: 68 Barracuda front vent window installation [Re: kentj340] #1694106
11/04/14 10:04 PM
11/04/14 10:04 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
Huge help, especially the pics..thanks so much...
