Ready to install the vinyl top on my 68 GTS and have run into a snag. During the build we ended up replacing the top on the Dart. Unfortunately we used the top off a non vinyl top car. Apparently the non vinyl top cars didn't have the triangular trim pieces mounted to the c piller so no holes for the trim.
Unfortunately we threw away the old top which had the holes drilled. So, is anyone working on Dart with a vinyl top. I need some pictures and measurements on where to drill the holes. Preferably from a top that doesn't have the vinyl installed. Any help will be appreciated.
