Re: 440 Bell housing 2468372
[Re: 6t5b440]
#1693983
11/03/14 08:41 PM
11/03/14 08:41 PM
RapidRobert
If no answer "Brewers" may have info on their site.
[Re: 6t5b440]
#1693984
11/03/14 08:55 PM
11/03/14 08:55 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Will this bell housing work in a 70 Challenger 440??
Yes it will. Depending on what the original application was, you might need to change the clutch fork pivot inside the bellhousing. Keep in mind this bell also has the small 4.354" bearing retainer hole. If your not sure on the pivot post a picture or email it to me.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: 6t5b440]
#1693985
11/04/14 04:23 PM
11/04/14 04:23 PM
Posts: 26,041 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The 372 bellhousing is BB but it never came on a 440, the Z-bar pivot ball will likely be in the wrong position for an E-body.
[Re: John_Kunkel]
#1693986
11/04/14 07:22 PM
11/04/14 07:22 PM
Posts: 4,285 Ohio
64dodge572
Ohio
The pivot loctions on the side of the 372 bellhousing are in the exact same place as the 10.5" alum 513 bellhousing. The only dimensional differences would be the bearing retainer hole.
