Holley Carb question with video #1693659
11/02/14 09:21 PM
11/02/14 09:21 PM
Tucson, AZ
Ramrod39 Offline OP
My New Title
Ramrod39  Offline OP
My New Title
Tucson, AZ
Pulled the Dart out of hibrenation today and it was running really rich. Took a look down the 650 Holley and saw this. This isn't right, is it? What do I need to do?
http://youtu.be/rMPVIcfoZLc
Re: Holley Carb question with video [Re: Ramrod39] #1693660
11/02/14 09:31 PM
11/02/14 09:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Nope, you've got a sticky needle valve...try rapping on the bowl.
Re: Holley Carb question with video [Re: John_Kunkel] #1693661
11/02/14 09:33 PM
11/02/14 09:33 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
Re: Holley Carb question with video [Re: Dan Halen] #1693662
11/02/14 10:04 PM
11/02/14 10:04 PM
Tucson, AZ
Ramrod39 Offline OP
My New Title
Ramrod39  Offline OP
My New Title
Tucson, AZ
And if tippy-tapping on the rear bowl doesn't work?
I'm not clear on where the needle and seat is on this carb. If I pull the carb and rear bowl will it be self explanatory? Is that the correct next step?
Re: Holley Carb question with video [Re: Ramrod39] #1693663
11/02/14 10:16 PM
11/02/14 10:16 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Looks like the secondaries are stuck open a hair, causing fuel to be pulled in to engine.
Re: Holley Carb question with video [Re: buildanother] #1693664
11/02/14 10:26 PM
11/02/14 10:26 PM
SW CO
HemiSportFury Offline
SW CO
Yep, it's very obvious where it is. Looks like a center pivot float so the needle and seat are just below the adjusting screw in the middle of the bowl. Also the float may have developed a leak and is sunk keeping the needle open.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: Holley Carb question with video [Re: Ramrod39] #1693665
11/02/14 11:30 PM
11/02/14 11:30 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Get yourself a copy of Mike Urich's little book on Holley 4150/60 carburetors, new or used. It's got good pictures and diagrams, and is pretty easy to read.
What you are seeing is the result of too high a fuel level in the secondary fuel bowl. The answer others have given a likely reason as to why it is overfilling. The book will help this all make sense.
