Re: Holley Carb question with video
[Re: Ramrod39]
#1693660
11/02/14 09:31 PM
11/02/14 09:31 PM
Posts: 26,011 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Nope, you've got a sticky needle valve...try rapping on the bowl.
[Re: buildanother]
#1693664
11/02/14 10:26 PM
11/02/14 10:26 PM
Posts: 530 SW CO
HemiSportFury
SW CO
Yep, it's very obvious where it is. Looks like a center pivot float so the needle and seat are just below the adjusting screw in the middle of the bowl. Also the float may have developed a leak and is sunk keeping the needle open.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: Ramrod39]
#1693665
11/02/14 11:30 PM
11/02/14 11:30 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
I'm not clear on where the needle and seat is on this carb.
Get yourself a copy of Mike Urich's little book on Holley 4150/60 carburetors, new or used. It's got good pictures and diagrams, and is pretty easy to read.
What you are seeing is the result of too high a fuel level in the secondary fuel bowl. The answer others have given a likely reason as to why it is overfilling. The book will help this all make sense.
