Charging isssue #1693653
11/02/14 09:16 PM
11/02/14 09:16 PM
Cincinnati Oh
fasthawk6 Offline OP
Cincinnati Oh
I run a 75 amp powermaster alt and my amp gauge is all over the place. headlights even fluctuate as the amp gauge does.
Re: Charging isssue [Re: fasthawk6] #1693654
11/02/14 09:37 PM
11/02/14 09:37 PM
Andrewh Offline
Andrewh  Offline
what voltages are you seeing?
what vr are you using?
what changed?
Re: Charging isssue [Re: Andrewh] #1693655
11/02/14 10:03 PM
11/02/14 10:03 PM
Cincinnati Oh
Cincinnati Oh
voltage is all in the 13's but all over, just not a steady out put. I have tried most all vr's from you usually parts stores. I had the best luck with the old black square box style. I ran extra grounds from motor to body to.
Re: Charging isssue [Re: fasthawk6] #1693656
11/02/14 10:52 PM
11/02/14 10:52 PM
Toss the OE alt back in & see if it straightens out
Re: Charging isssue [Re: RapidRobert] #1693657
11/05/14 02:40 PM
11/05/14 02:40 PM
Montana
DDodger Offline
DDodger  Offline
Montana
could be lots o things including alternator
bad connections in several places, you have old new harness?
Re: Charging isssue [Re: DDodger] #1693658
11/08/14 11:45 PM
11/08/14 11:45 PM
Cincinnati Oh
Cincinnati Oh
Sorry I have not got back in here, work has been kicking my butt but when I get a chance I will toss the alt back on but I am pretty sure it did it with the oem alt and the powermaster just magnified the problem if I remember.
