Page 1 of 3 1 2 3
Any Sm/Blk brackets for this Alum. P/S Pump setup yet? #1693408
11/01/14 11:57 PM
11/01/14 11:57 PM
So Cal
autoxcuda Online content OP
autoxcuda  Online Content OP
So Cal
These are pretty common for Street Rod and such now. You can get them with aluminum pump bodies (1.4lbs lighter than identical iron version).
Like this: http://www.detroitspeed.com/Steering/090901-aluminum-steering-pump.html
I bought this at the Fall Fling show last Saturday for $5. I figured it would be a no brainer aluminum housing (most are iron) for mockup. This turned out to be brand spanking new, just covered in dust!!
They also use this same pump housing setup in Circle Track cars for remote reservoirs and AN fittings.
I've also got a used KRC pump and remote reservoir and lines for mockup.
Deal is the "Dodge 360" bracket KRC sells is for a Magnum motor and you have to add a brace to make it work: http://www.jegs.com/i/KRC/612/31515000/10002/-1?parentProductId=
Note: This bracket uses three mounting points. Some engines may not have the upper right mount (facing the bracket) and may require the creation of a brace.
AndyF? (www.arengineering.com)
Jerry? (www.sdconcepts.com)
others?
I think because KRC list's a "Dodge 360" bracket, the rest of the aftermarket thinks the market is covered for this part/need.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: autoxcuda] #1693409
11/01/14 11:59 PM
11/01/14 11:59 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I was just thinking about this. Our PS pumps are so large and bulky. I was wondering why someone hasn't done this yet.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: MuuMuu101] #1693410
11/02/14 12:13 AM
11/02/14 12:13 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I have made brackets, twice, for that pump. First on the BB, and then to my Gen III. Real easy to make. I cant remember if I used a SB Chevy block mount or head mount bracket, but those are relatively cheap and using those you can make a mount to adapt them to your engine with some 1/4" aluminum plate. Heres a pic of the BB.....
Mopar to the bone!!!
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: 72Swinger] #1693411
11/02/14 12:18 AM
11/02/14 12:18 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
If anyone is interested, I have this mount and the V belt aluminum pulley still. Shaft on mine is .662 ish. Another thing of note is the smaller the shaft diameter, the bigger (better) the bearing is on these pumps.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: 72Swinger] #1693412
11/02/14 12:25 AM
11/02/14 12:25 AM
So Cal
So Cal
Here was the last go around on this subject:
https://board.moparts.org/ubbthreads/show...amp;Search=true
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: 72Swinger] #1693413
11/02/14 12:26 AM
11/02/14 12:26 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Just curious... How do the specs on this pump differ from our 45 year old pumps?
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: MuuMuu101] #1693414
11/02/14 12:35 AM
11/02/14 12:35 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I don't have any specs, but I can tell you it worked awesome when I ran it. I ran a cooler and RP Max EZ fluid just because heat is the enemy of all things hydraulic. My Borgeson loved it and stock pumps work fine on Borgesons???
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: 72Swinger] #1693415
11/02/14 12:41 AM
11/02/14 12:41 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Same exact pump bolted to my 6.1 here. Bracket not "cleaned up" yet.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: 72Swinger] #1693416
11/02/14 12:43 AM
11/02/14 12:43 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
I'm just looking for other options. I figured something could be adapted that was smaller to work with out PS boxes.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: MuuMuu101] #1693417
11/02/14 01:05 AM
11/02/14 01:05 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Find a better option let me know. 6.5 lbs w/ bracket and pulley.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: 72Swinger] #1693418
11/02/14 01:07 AM
11/02/14 01:07 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
By "other" I meant deterring the stock setup. I think the idea of using this pump is great. I'd definitely want to do this swap in the future.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: 72Swinger] #1693419
11/02/14 01:24 AM
11/02/14 01:24 AM
So Cal
So Cal
The .662 is the diameter of the one I have pictures in my first post.
The KRC I have has the same diameter where it meets the seal (and I assume bearing). But the KRC has a different end to take a nut and spline type pulley.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: MuuMuu101] #1693420
11/02/14 01:31 AM
11/02/14 01:31 AM
So Cal
So Cal
Some features and benefits listed for the unit sold on the Detroit Speed and Engineering site:
(Caution other pump and reservoirs may have different PSI settings and possibly flow rates)
Power Steering Pump - Aluminum with Integral Reservoir
Detroit Speed's power steering pumps are compatible with any power steering gear or rack and pinion. All pumps are completely new and are not remanufactured. DSE pumps deliver constant flow under given operating pressures. The transverse bearing compact pumps (TC pumps) are less sensitive to radial belt loading than other types of pumps.
Detroit Speed and Engineering power steering pump specifications:
• Flow = 3.0-3.4 gallons per minute at 1500 rpm
• Pressure relief = 1250-1450 psi
• TC pumps offer high efficiency and quite operation
• All DSE pumps are compatible with Vintage Air's Front Runner accessory drive system
• Features a 0.662" shaft diameter
• All pumps, including those with an integral reservoir, fit within the Front Runner confines
• All pumps are available with Mustang II flow control valve. This flow control fitting will restrict the flow to approximately 2 gal/min while retaining the
appropriate pressure in the system
This power steering pump offers the same performance characteristics as our other pumps, and it saves 1.4 pounds over the cast iron version. The aluminum housing has a cast aluminum finish and the integral reservoir makes for a clean, compact package.
Tech Tip: Pulleys must be installed with proper power steering pulley installation tool; KD Tool #2897. Do not use a hydraulic press!
Note: You will need to add a pressure fitting to your GM Type II pump to complete this hose kit. You can choose from 091702 hardline pressure tube, 090401 outlet fitting, or 091801 banjo pressure fitting.
I'm guessing the flow rate and PSI are in this same ballpark for other parts store replacement units.
I do not think this is specially made for Detroit Speed and Engineering. IMHO, it's a new off the shelf replacement unit for some production car. I don't know that for sure, but I have a strong feeling.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: autoxcuda] #1693421
11/02/14 01:32 AM
11/02/14 01:32 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Hey cool! I have one of those pumps too!
I was going to use it on a 572 engine I was going to build.
So this can be used on a Gen 3 engine right? What pulley and other stuff would I need? Part numbers?
Thanks!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: autoxcuda] #1693422
11/02/14 01:40 AM
11/02/14 01:40 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I agree Steve^^^^. These pumps are used on Cummins Dodges, SRT's, Malibus, Corvettes, Vipers, Cherokees, and some Imports. The GM models are where the reservoir came from on yours and mine though, but I cant tell you what model. The Mopars usually have a funky detached/semi-remote reservoir, that is fine, but ugly.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: RylisPro] #1693423
11/02/14 01:45 AM
11/02/14 01:45 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Thanks!
I cant remember the part number, but its a Dorman Ram 1500 PS pulley on mine for IIRC a 4.7. I used a 1/2" aluminum plate and adapted it to the cylinder head on my 6.1. It ends up about 1/2 a groove off of perfect so when the time comes I will just use my pulley puller to get it perfect.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: MuuMuu101] #1693424
11/02/14 01:47 AM
11/02/14 01:47 AM
So Cal
So Cal
The actual pump is very small. This is the pump the Circle Track racing power steering manufacturers have chosen to design their systems around and produce aftermarket custom parts for. There are flow control valves readily available to change the flow rate and other parts to change the PSI.
It's a proven unit with less expensive and readily available parts for you individual customization.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: autoxcuda] #1693425
11/02/14 01:50 AM
11/02/14 01:50 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
See, this is what I like about it... Whenever I look at pictures of people who put turbos on small blocks in A-bodies, they always say they had to convert to a manual steering box because the old pump was in the way. If I ever decide to go that route, it's nice to know there is another option to aid having both PS and boost.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: autoxcuda] #1693426
11/02/14 01:51 AM
11/02/14 01:51 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Dorman 300-313 pulley for the Gen III guys.
Re: Any Sm/Blk brackets for this Alum. P/S Pump setup yet? [Re: RylisPro] #1693427
11/02/14 01:52 AM
11/02/14 01:52 AM
So Cal
So Cal
Thanks!
KRC, Speedway, CV Products, and lots of other Circle Track supply places make lots of aluminum pulleys for it. I have an aluminum V-groove pulley that is 6" diameter. Don't know if that is the diameter I need, just picked it up for cheap to start mockup.
Page 1 of 3 1 2 3
