Re: Roller cam choices - who else to check with? [Re: B3422W5] #1693094
11/04/14 12:26 PM
11/04/14 12:26 PM
an8sec70cuda Offline
I have a ton of respect for Dwayne Porter. That is who I have used for cams and would again....guy is ultra knowledgable and very good at gathering combo info and intended usage and being spot on.
Fun guy to talk to as well, really pleasant.
Dwayne spec'd the cams in all my stuff.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Roller cam choices - who else to check with? [Re: an8sec70cuda] #1693095
11/05/14 03:05 PM
11/05/14 03:05 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I have two solid rollers to try w/ my new engine combination. One came from Dwayne Porter (802)951-1955 (who also spec'd & supplied my last solid flat-tappet cam) and the other is from a company that was also mentioned above with whom I've had no other prior experience. I won't mention who the other company is, simply because I have no results on which to base a recommendation.
