Plastic behind door panels - Important? #1692847
10/31/14 01:45 PM
10/31/14 01:45 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Guys,
I may be trying to get my door panels (73 Charger) back together here and I have a question about putting in the plastic sheeting behind the panels. Do you guys put that back in when you re-do your doors?
My plastic sheeting is long gone as it was torn to heck when I pulled the panels years ago. Should I be worried if I don't make new sheeting or just leave it out and go?
I'm guessing it was there for condensation not rotting out the backs on the interior panels but mine were still pretty bad.
If I do need to replace it, what do you recommend to use as the glue/putty to re-attach to the door? Also does anybody have a picture of this from a 71-74 B-body?
Thanks!
Re: Plastic behind door panels - Important? [Re: cjskotni] #1692848
10/31/14 01:48 PM
10/31/14 01:48 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
No pictures to offer. I didn't put any back in mine, (70 Satellite) instead I had dynamat in its place. I know it does make it a little quieter, and sometimes louder...
...FAFO...
Re: Plastic behind door panels - Important? [Re: skicker] #1692849
10/31/14 02:06 PM
10/31/14 02:06 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
Helps keep dust from finding it's way into the interior compartment too
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: Plastic behind door panels - Important? [Re: skicker] #1692850
10/31/14 02:10 PM
10/31/14 02:10 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
I'm guessing it was there to protect the interior door panels (which were made of a fiberboard-like material) from getting wet if water came in from above (e.g. rain or car wash).
Re: Plastic behind door panels - Important? [Re: Fab64] #1692851
10/31/14 02:17 PM
10/31/14 02:17 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
They help keep water & dirt out, they came on cars with plastic door panels also.
Re: Plastic behind door panels - Important? [Re: Alaskan_TA] #1692852
10/31/14 02:31 PM
10/31/14 02:31 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
Some heavy mil visqueen plastic with rope caulk and you are all set.
Whatszup? Barry!
Re: Plastic behind door panels - Important? [Re: Slotts] #1692853
10/31/14 02:41 PM
10/31/14 02:41 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Do you need it on a resto that is going to be a weekend driver? probably not though I'd worry about damaging the door panels when washing the car.
You don't need anything special: I used regular poly sheeting with butyl tape. Cheap and done.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Plastic behind door panels - Important? [Re: DPelletier] #1692854
10/31/14 04:59 PM
10/31/14 04:59 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Just basically used as a vapor barrier. Sheet plastic will work in its place or the original type is available...cr8crshr/Bill
Re: Plastic behind door panels - Important? [Re: CR8CRSHR] #1692855
10/31/14 05:17 PM
10/31/14 05:17 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
I'd use 6 mil poly vapor barrier. To attach it I'd use "removable" caulk - you can buy that at Home Depot.
Re: Plastic behind door panels - Important? [Re: Stanton] #1692856
10/31/14 06:23 PM
10/31/14 06:23 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Yes put it back on and tuck into the slot at the bottom of door. The rain will run down the window into the door then travel to the back side of door panel then to carpet and rust the floor out. It was put there for a reason from the factory. Get the plastic sealed, front and back glass,then have someone hose it and get inside and watch hor leaks, you'll be glad you did.
Re: Plastic behind door panels - Important? [Re: cjskotni] #1692857
10/31/14 06:57 PM
10/31/14 06:57 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Do like some of the other's have said, and put plastic back in, cut it to size, and 3M spray adhesive in the right locations will work just fine.
Re: Plastic behind door panels - Important? [Re: 71birdJ68] #1692858
10/31/14 08:13 PM
10/31/14 08:13 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
An even better idea for protecting the doorpanels is to coat them with polyurethane (the hardboard side, that is).
Re: Plastic behind door panels - Important? [Re: Fury Fan] #1692859
10/31/14 08:39 PM
10/31/14 08:39 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Like i said its to keep the rain- moisture out
Re: Plastic behind door panels - Important? [Re: cjskotni] #1692860
10/31/14 08:43 PM
10/31/14 08:43 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
yes put them back in for sure, at least.
IMO the plastic helps mostly to reduce air flow into the passenger compartment when the car is going down the road, then all the other benefit's like dust, moisture, sound and more which add up to a quality built car. You can tell also when you close the door.
Re: Plastic behind door panels - Important? [Re: Challenger 1] #1692861
11/01/14 01:29 AM
11/01/14 01:29 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
This.
Re: Plastic behind door panels - Important? [Re: Twostick] #1692862
11/01/14 02:05 AM
11/01/14 02:05 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
No, for water
1969 Plymouth service manual page 23-64 body and frame. They are called watershields quote" Refer to figure 16 for sealing areas and applications of watersheilds. The bottom edge of sheild must be inserted into the slots in bottom of inner panels."
Re: Plastic behind door panels - Important? [Re: cudaman1969] #1692863
11/01/14 01:06 PM
11/01/14 01:06 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Thanks, guys! I guess I will be fab'ing these and putting them back in.
I appreciate the feedback. I will go look for the 6 mi vapor barrier and rope/removable caulk from the hardware store this weekend.
Cheers!
Re: Plastic behind door panels - Important? [Re: cjskotni] #1692864
11/01/14 01:16 PM
11/01/14 01:16 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Glad this question was asked.
Now I won't be skipping the plastic sheet either.
Mo' Farts
Moderated by "tbagger".
